So I was really surprise to see this discussion getting more attention, went from 4 yesterday last I looked to 14 now.
Rockedge, To answer your question ( Fri Apr 28, 2017 8:20 am) as it applies to me, "What Url .... "this is what is so maddening and disappointment, the url that I have in the Source panel is the same one that I use on three other ZM instillations and they all worked correctly. When I just paste this url in firefox it just works beautifully, "
http://192.168.5.97/videostream.cgi?use ... esolution= 8 => 320x240 32 => 640x480 ". So to recap, I still have no streaming video when I click on the monitor in my case its "Mn6_Backdoor" its just a white screen, but I'm getting detection alarms when I click on the alarm/events I see no video. I have stills and if I click on the still I see the individual images making up what would be the video.
From all the reading I been doing ( and there has been a lot since April 24th) it should be fixed with the info here, "Why can’t I see streamed images when I can see stills in the Zone window etc?" - Again this is the info I first posted when I started this thread. See above. These are the same issues that Lilmissndemon is having.
But Here are the particulars of my setup.
- Monitor6-SourceSettings.png (43.23 KiB) Viewed 10641 times
Shows Source settings
- Mn6Monitor_NoVideoStreeming_butALARMS.png (21.17 KiB) Viewed 10641 times
Shows Monitor 6 with no streaming video but shows the alerts..
- Event886_WithStills_NoVideo.png (286 KiB) Viewed 10641 times
Shows Monitor 6 with 3/51 stills (frames) that would make up the video.
Lilmissndemon - Sorry you are having the same issues ? Here are a couple of things to check.
Is your setup recording alerts/alarms? and do you see no video, but can see stilsl like those I've outlined above?
Your setup for "/etc/apache2/conf-enabled/zoneminder.conf, ScriptAlias /zm/cgi-bin "/usr/lib/zoneminder/cgi-bin" and options for PATH_ZMS /zm/cgi-bin/nph-zms are correct.
What kind of camera are you using with ZM? Perhaps if I know the type of camera I can review your setup since at one point you were having blue screen issues, and this is usually a camera configuration issue.
