SOLVED: [new idea] autologin for simple montage wit firefox
krzys31337
Post by krzys31337 »
I'm setting up really simple "DEMO" box.
It has 15" 1024x768 LCD display for seciurity officer.
I'm running firefox like that:
=montage&group=0&mymagic=xxx&luser=u&lpass=p'
Changing top of file zm_html.php:
And got as far as "username:" filled with "u" (of course without ZM_OPT_USE_AUTH it works OK -- montage seems good for 4 cameras 2 fps each).
Maybe some advices how to do it better ? (another idea will be modify zm*html*php when it has "_GET[password]" and copy it to _SESSION but it's a crude way).
But this solution works for me and allows to convice some manager to find additional Euros/USDs for ZM.
//ini_set( "magic_quotes_gpc", "Off" );
require_once( 'zm_config.php' );
require_once( 'zm_lang.php' );
require_once( 'zm_funcs.php' );
require_once( 'zm_actions.php' );
if ( ZM_OPT_USE_AUTH )
        session_start();
        if ( isset( $_SESSION['user'] ) )
                $user = $_SESSION['user'];
        elseif ( isset( $_GET['mymagic']) )
                userLogin($_GET['luser'],$_GET['lpass']);
        else
                unset( $user );
btw: find /usr/lib/mozilla-firefox/greprefs/all.js and set:
// limit the absolute number of http connections that can be established per
pref("network.http.max-connections-per-server", 16);
pref("network.http.max-persistent-connections-per-server", 16);
pref("network.http.max-persistent-connections-per-proxy", 16);
zoneminder
Site Admin
Post by zoneminder »
Good. I'm glad you got it working. I think you _should_ be able to just use an url to log in and display but I've not tried and if your solution works then so much the better and I'm sure other people will be interested.
Phil
krzys31337
Some other thougts:
It's good to do:
xset dpms 0 0 0
The patch against 1.21.3 (works with 1.21.X) is here:
http://cvs.pld-linux.org/cgi-bin/cvsweb ... _get.patch
And/or have this in X11.conf:
Section "InputDevice"
        Identifier  "Keyboard0"
        Driver      "void"
EndSection
        Identifier  "Mouse0"
        Driver      "void"
EndSection
Option          "DPMS" "False"
And run firefox in some watchdog loop (kill it every 1..24 hours?)
Some screenshot (1'st try) (images were taken by "xvidcap",
mpeg/avi files were done using ffmpeg, load average while capturing was somwhere 3.5~3.8).
[/code]
and after some clickety-clicking...
Best Regards and sorry for my poor english...
krzys31337
Here you will find pictures and some mpg file.
http://pancake.sggw.waw.pl/~hunter24/bttv/
Should I put this thread in Contrib forum?
krzys31337
Phill,
Please some advice and your voice on subject:
i'm in some strategic point:
Yes, it's a blank X11, w/o even simplest window manager and fetching:
/cgi-bin/zms?mode=single&monitor=5&user=r&pass=r&maxfps=5
Are you interested in that stuff, maybe it would be better to skip X11 and use DirectFB or SDL?
Are they images in shm in jpeg-encoded format or they are some how "raw" ?
The app takes pics and checks response code (304 in http-lang means "not modified"):
Got 200 from http_headers() - 26331 bytes of content
Got 304 from http_headers()
Got 200 from http_headers() - 26436 bytes of content
Got 200 from http_headers() - 26351 bytes of content
Got 200 from http_headers() - 26420 bytes of content
Got 200 from http_headers() - 26369 bytes of content
Got 200 from http_headers() - 26426 bytes of content
Got 200 from http_headers() - 26329 bytes of content
Note:
some "1 + 5" shema (known from hardware video spliter) is also possible:
Overhead on using mozilla-firefox on my box is not that big:
cordel
Post by cordel »
I emailed Roy Souther as a courtesy asking him about eLViS. He said basically he has no problem with us adapting eLViS to work with ZoneMinder. I'll take a look at the code as I know there have been many requests for such an interface. Thank you for pointing this project out.
Regards,
Cordel
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
krzys31337
Yeap it will look like the good thing, some unification with motion (other monitoring software).
Note: elvis looks into jpg files, but ZM already has streaming part (zms as a cgi...) and shm interface which should be more then faster from file acces.
Right now I'm collecting some data (2xbttv on 2.4 Ghz celeron with 512 MB ram) and running "firefox" with montage of 4 cameras (PAL 380x240, RGB565 each one). I'm collecting only system load every 60s. It stays beetwen 0.15 to 0.30.
After some search on the net I've found some project (namely here: http://cvs.sourceforge.net/viewcvs.py/s ... talkercam/) and hope it could help me in droping load.
Using zms in "single" mode and quering second by second looks good -- not having firedup firefox gives me extra 90MB of ram!
Also i'm not using any thing exept libjpeg and X11 (not even a QT3).
If someone will explain/dropme a line about content/multipart I will replace executing CGI every minute for every frame with just having 4 CGI runnig.
It should also drop system load.
For simple montage on localhost we don't need any more then 1 FPS per each monitor, right?
krzys31337
ok i've found that:
zm_image.cpp
bool Image::initialised = false;
unsigned char *Image::abs_table;
unsigned char *Image::y_r_table;
unsigned char *Image::y_g_table;
unsigned char *Image::y_b_table;
It looks like raw image, so taking data from here and writing to X11/DirectFB would be the most efficent way, right?
cordel
Post by cordel »
I think the best idea would be to work on having the app pull strait from the memory (shm) to keep the overhead down. another possiblity is to use loopback but I don't know if all the distros have that compiled into the kernel so some research is in order before going the later direction. One fps should be suitable and easy to accomplish but I think it might be fesable to see 5 fps or better with out to much load or overhead.
Regards,
Cordel
3939663646337
-Mark Twain
krzys31337
.a
krzys31337
Ok, got some stats (might be very inacurate).
The method is:
every miniute do:
/usr/bin/rrdtool update load.rrd N:$(cut -d " " -f 1 /proc/loadavg)
At "10:00" i've shut down firefox, and run 4 processes "leeching" jpgs with 1 fps and rendering to X11.
After 10:40 i've add montage (2 fps) from antother host by net.
As we can see, it's obvious. Local montage is worth implementing without browser or java.
