v1.30.3 on Ubuntu 14.04 - All good!
JRoque
Post by JRoque »
Hi all,
Seeing some of the issues being posted regarding the v1.30.3 upgrade, I wanted to pass on that mine upgraded great. I run ZM on Ubuntu 14.04 and used Webmin to do the upgrade - entirely hands-off, zero issues.
More: I'm running ZM on an old laptop with an Intel i3, 2-core CPU and 4GB of RAM. CPU utilization with 4, 720p cameras on Modect runs <40% CPU.
Thanks to the Devs and package maintainers.
Cheers,
JR
Re: v1.30.3 on Ubuntu 14.04 - All good!
Did Webmin install php5-apc when you upgraded Zoneminder? If not you will have to install it manually or with Webmin.
JRoque
Post by JRoque »
Hi. Yes, Webmin did that for me, entirely hands off:
The following extra packages will be installed:
  php5-apcu    <<<<<--- here
Suggested packages:
  bash-doc fcgiwrap
The following NEW packages will be installed:
  php5-apcu
The following packages will be upgraded:
  bash fonts-opensymbol libicu52 zoneminder zoneminder-doc
5 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 19.2 MB of archives.
After this operation, 336 kB of additional disk space will be used.
Get:1 http://us.archive.ubuntu.com/ubuntu/ trusty-updates/main bash amd64 4.3-7ubuntu1.6 [575 kB]
Get:2 http://us.archive.ubuntu.com/ubuntu/ trusty-updates/main libicu52 amd64 52.1-3ubuntu0.6 [6745 kB]
Get:3 http://ppa.launchpad.net/iconnor/zoneminder/ubuntu/ trusty/main zoneminder amd64 1.30.3-trusty8 [6399 kB]
Get:4 http://us.archive.ubuntu.com/ubuntu/ trusty-updates/main fonts-opensymbol all 2:102.6+LibO4.2.8-0ubuntu5.1 [110 kB]
Get:5 http://us.archive.ubuntu.com/ubuntu/ trusty/universe php5-apcu amd64 4.0.2-2build1 [73.2 kB]
Get:6 http://ppa.launchpad.net/iconnor/zoneminder/ubuntu/ trusty/main zoneminder-doc all 1.30.3-trusty8 [5309 kB]
Fetched 19.2 MB in 49s (389 kB/s)
(Reading database ... 235117 files and directories currently installed.)
Preparing to unpack .../bash_4.3-7ubuntu1.6_amd64.deb ...
Unpacking bash (4.3-7ubuntu1.6) over (4.3-7ubuntu1.5) ...
Processing triggers for install-info (5.2.0.dfsg.1-2) ...
Processing triggers for man-db (2.6.7.1-1ubuntu1) ...
Setting up bash (4.3-7ubuntu1.6) ...
update-alternatives: using /usr/share/man/man7/bash-builtins.7.gz to provide /usr/share/man/man7/builtins.7.gz (builtins.7.gz) in auto mode
Preparing to unpack .../libicu52_52.1-3ubuntu0.6_amd64.deb ...
Unpacking libicu52:amd64 (52.1-3ubuntu0.6) over (52.1-3ubuntu0.5) ...
Preparing to unpack .../fonts-opensymbol_2%3a102.6+LibO4.2.8-0ubuntu5.1_all.deb ...
Unpacking fonts-opensymbol (2:102.6+LibO4.2.8-0ubuntu5.1) over (2:102.6+LibO4.2.8-0ubuntu5) ...
Selecting previously unselected package php5-apcu.
Preparing to unpack .../php5-apcu_4.0.2-2build1_amd64.deb ...
Unpacking php5-apcu (4.0.2-2build1) ...
Preparing to unpack .../zoneminder_1.30.3-trusty8_amd64.deb ...
Unpacking zoneminder (1.30.3-trusty8) over (1.30.2-trusty1) ...
Preparing to unpack .../zoneminder-doc_1.30.3-trusty8_all.deb ...
Unpacking zoneminder-doc (1.30.3-trusty8) over (1.30.2-trusty1) ...
Processing triggers for fontconfig (2.11.0-0ubuntu4.2) ...
Processing triggers for ureadahead (0.100.0-16) ...
Processing triggers for doc-base (0.10.5) ...
Processing 1 changed doc-base file...
Registering documents with scrollkeeper...
Setting up libicu52:amd64 (52.1-3ubuntu0.6) ...
Setting up fonts-opensymbol (2:102.6+LibO4.2.8-0ubuntu5.1) ...
Setting up php5-apcu (4.0.2-2build1) ...
php5_invoke: Enable module apcu for cli SAPI
php5_invoke: Enable module apcu for apache2 SAPI
Setting up zoneminder (1.30.3-trusty8) ...
Installing new version of config file /etc/zm/zm.conf ...
Stopping ZoneMinder: success
Initiating database upgrade to version 1.30.3 from version 1.30.2
Upgrading database to version 1.30.3
Loading config from DB
Saving config to DB
Upgrading DB to 1.30.3 from 1.30.2
Database successfully upgraded to version 1.30.3.
Database upgrade to version 1.30.3 successful.
Freshening configuration in database
Saving config to DB
Done Updating, starting ZoneMinder
Starting ZoneMinder: success
Regards,
JR
Thanks for the reply. I usually do not recommend Webmin to do Zoneminder updates or upgrades so it is good to know it worked for you.
