hello!
do you have an idea to fix this problem when running 'perl ./zmconfig.pl'
[root@localhost zm-1.21.2]# perl ./zmconfig.pl
Loading config from 'zmconfig.txt'
DBI connect('database=zm;host=localhost','toto',...) failed: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) at ./zmconfig.pl line 1662
Error: unable to load options from database: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
thank you!
kv
That is normal error. It's because you have not set up your database yet. Just follow the README and you'll do okay. You have to setup the database a little later then run perl zmconfig.pl -noi to populate the database.
Regards,
Cordel
Regards,
Cordel
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
