I've read somewhere that in Montage you're using 20% of screen width for each tile's width, making 5 each row. Is there any possibility of let that percent to be changed in Developer Settings? You see, if I could set it to 16% or some, there would be room for 36 tiles on screen, ideal for my setup.
Also, it would be nice if I could hide some menus from the left, maybe with an administrator password. I don't want to be called at midnight because someone broke the configuration, just because he was bored and touched everything
In Montage Profiles I think there should be a "Default" option with all the cameras. I've made one profile for each level of my building with their respective monitors, but I have to create one more with all of them just for this purpose.
And the last one I promise, just an aesthetic one. In the monitor selection list (the one with the eyes) could you make the disabled monitors show in red or something? With 30+ monitors it would be very helpful.
Thank you again, keep up the good work.
*EDIT: I Just found out that if you have a Montage profile with, let's say, 3 monitors and in ZM you add new monitors, when you come back to that profile it shows the 3 old monitors and the new ones. Maybe this shouldn't be the correct behavior? I mean, keep the profiles the way they were made and add the new ones only if you want. Thanks again!!!
