Adding a GPU card
hokedigital
Adding a GPU card
Post by hokedigital »
I'm running an i5 with 8 x 5mp cameras H265
If I install a GPU card, would this increase the processing power or take the load off the CPU?
Thank you
Tom
Re: Adding a GPU card
No. Assume you are running a server? GPU are for desktops.
Add more RAM if you can. That is where you will gain the most. My i5 runs 17 cameras without a problem.
hokedigital
Im using Ubuntu 16.04 LAMP 16G ram
also looking at testing 4K cameras
OpenCV can be compiled to use GPUs
epruesse
Post by epruesse »
Probably yes. You may have to mess with some libavcodec configuration though.
The recommended settings tell you to set ZoneMinder to use "ffmpeg". Behind the scenes, ZoneMinder uses libavcodec to expand the h.264 stream to images. This library is theoretically capable of using hardware acceleration both from GPU and CPU. E.g. I'm noticing distinct differences in CPU load if my stream becomes wider than 2048px as that is the max my older Intel CPU can do hardware acceleration on.
Please post if you managed to make it work, and how you did it.
bartekn86
Post by bartekn86 »
ihave compiled ffmpeg
root@nas:/etc/apache2# ffmpeg
ffmpeg version N-87160-g9aa2469930 Copyright (c) 2000-2017 the FFmpeg developers
built with gcc 6.3.0 (Debian 6.3.0-18) 20170516
configuration: --enable-cuda --enable-cuvid --enable-nvenc --enable-nonfree --enable-vaapi --enable-vdpau --enable-libmfx --enable-nonfree --enable-libnpp
ffmpeg -hwaccel shows
Hardware acceleration methods:
vdpau
qsv
vaapi
cuvid
but nvidia-smi shows nothing while previev a "monitor" images... such as intel_gpu_top when i putout GF630 out from pc
tested on gt630 @ drivers Driver Version: 375.66
and j3455 cpu with hd500 igpu (qsv/vaapi method)
iconnor tell that he tested some hwardwarre acceleration but how make it usefull if sb have any experience/advice many people will be grateful
bartekn86
Post by bartekn86 »
isnt vaapi for intel gpu ? (igpu) nvidia drivers istalled, ffmpeg compiled from nvidia sdk ffmpeg tutorial... nothing happens...
is it any option to run zmc -m without generating jpeg/mpg when nobody look at prev. from cam ?
bartekn86
Post by bartekn86 »
HI,
debian, vaapi, ffmpeg compiled by myself.. in htop i see that ffmpeg is run with -hwaccel auto/vpadu/vaapi but i dont see any gpu activity...
MalakymR
Post by MalakymR »
This post has been linked to via a blog from someone who thinks ZM has it in for them, and posts crap about ZM everywhere they can.
They put this at the bottom of the quote "- ZoneMinder Developer" as if this single message means everything when everyone below says its okay.
Then ends with this "Beware of false knowledge; it is more dangerous than ignorance."
Well if you are here from the medium.com post, you just read some "false knowledge".
bbunge wrote: Tue Jul 18, 2017 3:12 pm No. Assume you are running a server? GPU are for desktops.
Servers often have crippled vga chipsets and no gpu slots. I don't know why someone doesn't make a pcie x8 gpu card. Maybe they do and I havn't found it. I have played with a PCI zotac nvidia gpu and it worked ok.
vaapi is primarily for intel, but also works with mesa and amd and nvidia. cuda is better for nvidia.
MalakymR wrote: Thu Sep 19, 2019 7:58 am This post has been linked to via a blog from someone who thinks ZM has it in for them, and posts crap about ZM everywhere they can.
Well, I have to admit that I learn something new about computers just about every day. My comment about GPU's was based upon what I knew in 2017 but It wasn't "false" at the time for me.One of these days I'll likely figure out how to use a GPU to boost Linux horsepower. But for now I'll just search the junk piles for good discarded hardware that is better than what I already have...
MalakymR
Post by MalakymR »
bbunge wrote: Mon Sep 23, 2019 11:59 pm
This wasn't your fault - the other person was quoting you as a developer.
I'm actually going to link this here for posterity.
https://web.archive.org/web/20201103144 ... 6ByZYNPFCG
As I expected, the original was deleted, hence the link.
To quote the Shinobi page - "Beware of false knowledge; it is more dangerous than ignorance."
