Unable to get response, disconnecting
littlej
Post by littlej »
Hi, i have a Vivotek PZ6122 and it used to work on zoneminder 1.28.01 with the following settings :
Source Remote :
http / simple
host name : user:pass@ip
host path : /cgi-bin/video.jpg
widh/height 352 / 288
I upgraded to 1.28.108 and it stopped working, now i get the following error message:
2015-11-18 09:07:02.669075 zmc_m13 14457 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2015-11-18 09:07:02.650010 zmc_m13 14457 ERR Unable to read content zm_remote_camera_http.cpp 503
Any ideea what could it be wrong and how can i solve it ?
bench
Re: Unable to get response, disconnecting
Post by bench »
Any solution to this issue?
i`m new at this and have the sam problem / same camera, but latest version of ZM
Is your camera using port 80? Another post uses port 8088.
Resolution may need to be 320x240
berkedemel
Post by berkedemel »
I've added Dlink dcs-5300g IP camera after installing zoneminder 1.30.4 . I had this problem in the logs. Is there anyone who solved the problem?
By the way, I tried what you wrote above but it didn't work.
dabeast1973
Post by dabeast1973 »
I know this post is really old but I have the same issue using ZM 1.30.4 and Dlink DCS-3220 cameras :)
