zm-1.21.3 not starting after upgrade from 1.20.1
maclellan
Post by maclellan »
I get this error message in zmpkg.log:
Command: start
Executing su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl check'
/bin/sh: --shell=/bin/sh invalid option
Usage: /bin/sh [GNU long option] [option] script -file ...
GNU long options:
--debug
--dump -po strings
--dump -strings
--help
--init file
--login
--noediting
--noprofile
--norc
--posic
--rcfile
--restricted
--verbose
--version
--wordexp
Shell options:
-i rsD or -c command or -O shopt-option (invocation only)
-abefhkmnptuvxBCHP or -o option
Any ideas?
maclellan
Post by maclellan »
An update. I copied the old zmpkg.pl file from 1.20.1 and it works! I'm not sure if mixing versions and files is a good idea but this works for now.
cordel
Post by cordel »
What Distro are you using?
What version of make file, gcc, etc...?
Anything else you might be able to think of to give Phil a better picture?
Regards,
Cordel
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
zoneminder
Site Admin
Post by zoneminder »
Was this Slackware by any chance?
Phil
maclellan
Post by maclellan »
I'm using Gentoo - 2004.3 with all the standard stuff to run Zoneminder.
zoneminder
Site Admin
Try editing zmpkg.pl (or zmpkg.pl.z and then rerun zmconfig.pl, rebuild and reinstall) and changing
$command = "su ".ZM_WEB_USER." --shell=/bin/sh --command='$command'";
to
$command = "su ".ZM_WEB_USER." –c ’$command’";
This is something that has to be modded in Slackware, it may be the case in Gentoo also. I'd add support for both formats but I'm not sure how to detect which version to use.
Phil
Ruler
Post by Ruler »
I read the initial post and was going to suggest modifying the --command line. From the sound of it, especially with --command not listed in the error as a viable long option and the old source file fixing the problem, I'd bet that this is the cause.
Maybe somebody with a different distro can try this out, but does the -c (short form) work on non-slack distros? If it doesn't, possible make it a config option and wrap the execution inside an if. 1.21.0 compiled fine on slack; this will just produce errors when trying to use specific functions.
lazyleopard
Post by lazyleopard »
Yes, gentoo has the old-style su syntax...
Rick Hewett
