Raspberry pi3 and h264_mmal
Re: Raspberry pi3 and h264_mmal
Chris
My concern at this point is code structure. Seems like each hwaccell codec is going to require a lot of extra code to support. Need to structure the code well. I will be taking a look at your code in the very near future.
I am also using this thread to post ideas and solutions to obstacles that I've encountered so that If the code ever gets merged in some form, it would help others to have some notes on implementation. MMAL development is kinda cryptic. There is not much formal documentation but there is a good team of engineers in the RPI forums trying to answer sensible questions.
I am currently trying to implement a pipleline :
resizer -> splitter output 0 -> directbuffer
splitter output 1 -> h264 encoder -> mvect_buffer.
There are optimizations that could be done down the road such as :
1. Reducing the size of the video frame sent to the encoder in order to reduce the number of motion_vectors that need to be processed. This should greatly reduce the cpu utilization. Then have a full unresized frame sent to directbuffer for streaming. But that entails two resizers in the pipeline.
2. Use the hardware jpeg encoder. I don't know where to put it yet. Probably don't want to put it in zmc as that means jpeg buffers need to be mmaped as well increasing memory requirements. Plus, dont really need to jpeg encode all frames. Perhaps it could be in zms.
3. A native mmal h264 decoder can be implemented which would remove reliance on specially built ffmpeg.
4. The h264 encoder is already being used to output motion vectors, why not process the video frame data into an h264 stream.
5. Software and hardware motion vector processing require different buffer sizes. The hardware side requires a smaller mvect_buffer especially if resolution is downscaled prior to being sent to the encoder.
6. Only engage the zma mvect_buffer motion analysis if we think we have enough vectors to satisfy a minimum user specified score.
7. Second tier motion_vector validation by checking for minimum sized clusters. (performance hit).
8. Third tier motion_vector validation by checking if vectors in a cluster are oriented in the same direction (performance and memory hit as the magnitude of vectors need to be added to the motion_vector struct).
Bugs:
1. I notice that the frames in zms are sometimes out of order. Don't know how to fix that yet. Perhaps having a single pipeline with one entry point would fix the issue. Right now buffers are supplied to two entry points: encoder input and splitter input.
2. I had to make some changes to zmpkg.pl (not in the actual code branch) to get zoneminder to start
#Fix zmpkg.pl error with zmsystemctl.pl
cd scripts
sed -i -- '/systemdRunning.*calledBysystem/,+3d' zmpkg.pl.in
cd ..
Seems like the RPI is a very viable stand alone system for zoneminder. Kinda like zoneminder in a box once further optimizations are implemented. When RPI4 rolls out hopefully, all the issues have been ironed out.
I have just another week to work on this project because I am losing the cameras. They have to be shipped out. I'll do what I can. I can supply a package for people to test if I there is a place to host them and it doesn't violate any rules. However I wont be able to do any development for a while. I will also try to put up a howto on how to get it working. No guarantees.
Chris
I will try to work with mastertheknife to get the neon stuff fixed up.
In terms of a jpg encoder, it would be nice to have that in zms, although zma does a fair amount of jpg writing as well. (We do zone dump images, and writing of analysis images, etc).
The frames out of order in zms is interesting. I have seen that when running two copies of zmc simultaneously.
I really learn as I go. It turns out that there is a super secret efficient resizer in mmal that is undocumented in the headers and is present in the latest firmware. The vc.ril.isp can resize and convert to RGBA, RGB24 and GRAY8 (via I420). So there is no need for a splitter component. I also found out that mmal can handle any resolution and it does not need to be a multiple of 16. This is because VCOS_ALIGN_UP(width,32) and VCOS_ALIGN_UP(height,16) increases the buffer resolution to these multiples. The resulting converted buffer is bigger and the actual frame data in its original resolution is embedded in it with some padding. So the best way to handle hardware resizing is to add vcos_align_up in zm_monitor.cpp just before the creation of ffmpeg camera object. That way, the picture buffer allocated in zm_image will be appropriately sized for the inflated buffer. Otherwise, if the adjustment is done inside ffmpeg_camera object, zoneminder complains about the held buffer being too small and fails. This also ensures that the directbuffer is large enough to be memcpied to from mmal buffer. Otherwise, the software jpeg encoder gets confused and outputs garbage. Changing the resolution does mean that the zone dimensions need to be adjusted to fit the scaled down or scaled up frame. I haven't put that in yet. Somehow, that resolution change information needs to get to zma so it could scale the zone polygons. Or the zone polygons need to be automatically adjusted with each resolution change.
The alignment_trap shows up every now and then so it is not completely gone but I dont see it frequently. Somebody else who knows more about that stuff could look at the code. It happens only on some shutdowns and only on some pairs of zma's and zmc's.
I will see if I can get the parallel branch motion_vectors_pipeline up and running. This will utilize connections between components so the buffer is fed only in one entry point and multiple exit points can output specific buffer data types. This is what I was working on until I found out about vc.ril.isp. The connections will be simpler than I envisioned because of vc.ril.isp. I think I will enable the splitter component and connect its first output to the vc.ril.isp to resize/format_convert then save in directbuffer while splitter output 2 will connect to another vc.ril.isp component to downscale before sending the video to the encoder. That way, we have higher resolution frames in zms while zma is analyzing vectors from a lower resolution frame. As I mentioned earlier, there might be a performance penalty here because full data buffers are copied across components which is why I created a separate branch. I have to see if the splitter component can pass opaque buffers to vc.ril.isp. That would at least remove one full data buffer copy.
Regarding the out of sequence frames in zms, a pts value can be returned by mmal (if buffer->pts value is supplied to the mmal input side, perhaps using the frame number as a pts value ) and it could be saved along with directbuffer or a separate class member can save the value for each image. That might help with sorting frames when building the zms event stream.
Chris
Our job here is to encourage you to continue, and stick around. How can we do that? What do you need? By all means, take a break, but PLEASE stick around. This is exciting stuff.
Motion_vectors implemented:
avcodec --> h264encoder -->mvect_buffer
avcodec --> resizer -->directbuffer
avcodec -->splitter -> resizere -> h264 encoder -> mvect_buffer
-------> resizerd -> directbuffer
The resizere component downscales the video prior to motion vector extraction. The downscale is either 320x240, 640x480 or 960x720 which is user configurable. I used the Options field in the Source tab of Monitor to specify low, medium or high. I figured out how to rescale the zone polygons at the initiation of Load Monitor so the information about the size of the frame does not need to be passed to zma anymore via mmap. This also meant that the rescaling of the zones does not need to happen during the polygon inclusion test on zma which would have been a performance hit.
Things are working but I am still bugged by the out of sequence frames. Don't know what is causing that. There is only one buffer feeding the pipeline and buffers received from resizerd are checked to see if the pts value is not older than avcodec frameCount.
I found a clue though. When watching a live stream from the camera using zms, I noticed the time stamps on the upper right move back in time and jump forward again. Would you have an idea what could be causing that? It does not happen all the time. The event playback would also do the same thing seemingly to randomly jump back and forth.
I will be sticking around after taking a break. I am learning a lot doing this so I do have some benefit from it. I am just not sure of the value of this work eventually to your project as I don't know if it ever will be practical.
Chris
Chris
Chris
So I disabled the use of vc.ril.isp for now and restored the use of swscale for hardware side. Motion detection does work for both software and hardware decode. The dowscale part before the hardware encoder works, as well as the use of the Options field in the Source tab for the downscale mode (even though it complains about invalid options when the options are checked against valid ffmpeg options. The only part that does not work is the copying of the buffer data to directbuffer from vc.ril.isp. Somehow it messes up the event streamer with the timestamp going backwards and jumping forwards. This doesn't happen with swscale so the problem is probably on the mmal side. This is probably my last attempt for a little while. I hope I didn't break anything else on the last update to motion_vectors_connect.
Thanks,
Chris
1. Install Raspbian Lite Stretch. Update the system
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get install zoneminder
3. Allow user pi and www-data to access the video encoder
sudo usermod -a -G video pi
sudo usermod -a -G video www-data
sudo apt-get install libmp4v2-2
sudo apt-get install libapache2-mod-fcgid
sudo apt-get install libexpect-perl
sudo apt-get install netpbm
sudo apt-get install php-gd
sudo apt-get install libssl-dev
sudo apt-get remove zoneminder
sudo apt-get remove libjpeg8
*Build jpegturbo with jpeg8 support
sudo apt-get build dep libjpeg62-turbo
dh_auto_configure -- --with-build-date=$(DEB_VERSION) $(DISABLE_SIMD) --with-jpeg8
usr/lib/arm-linux-gnueabihf/libjpeg.so.8*
debuild -us -uc -b
*Install the packages.
sudo dpkg -i ./libjpeg-dev_1.5.1-2_all.deb
sudo dpkg -i ./libjpeg62-turbo-dev_1.5.1-2_armhf.deb
sudo dpkg -i ./libturbojpeg0-dev_1.5.1-2_armhf.deb
sudo dpkg -i ./libjpeg62-turbo_1.5.1-2_armhf.deb
sudo dpkg -i ./libturbojpeg0_1.5.1-2_armhf.deb
sudo dpkg -i ./libjpeg-turbo-progs_1.5.1-2_armhf.deb
5.Build and install the libraries for RPI userland
sudo apt-get install git
sudo apt-get install cmake
mkdir raspberrypi
cd raspberrypi
git clone https://github.com/raspberrypi/userland.git
cd userland
./buildme
sudo nano /lib/systemd/system/zoneminder.service
# ZoneMinder systemd unit file
# This file is intended to work with all Linux distributions
[Unit]
Description=ZoneMinder CCTV recording and security system
After=network.target mysql.service apache2.service
Requires=mysql.service apache2.service
[Service]
User=www-data
Type=forking
ExecStart=/usr/bin/zmpkg.pl start
ExecReload=/usr/bin/zmpkg.pl restart
ExecStop=/usr/bin/zmpkg.pl stop
PIDFile=/var/run/zm/zm.pid
[Install]
WantedBy=multi-user.target
*Create a file called zoneminder.conf
sudo nano /etc/tmpfiles.d/zoneminder.conf
d /var/run/zm 0755 www-data www-data
d /var/tmp/zm 0755 www-data www-data
*Change permissions on the file
sudo chmod 755 /etc/tmpfiles.d/zoneminder.conf
sudo /bin/systemd-tmpfiles --create /etc/tmpfiles.d/zoneminder.conf
sudo systemctl enable zoneminder.service
* Enable some modules
sudo a2enmod cgi
sudo a2enmod rewrite
sudo systemctl reload apache2
*Verify that zoneminder.conf is in /etc/apache2/conf-available, then
sudo a2enconf zoneminder
sudo nano /etc/php/7.0/apache2/php.ini
sudo chown -R www-data:www-data /usr/share/zoneminder/
mysql < /usr/share/zoneminder/db/zm_create.sql
mysql -e "grant select,insert,update,delete,create on zm.* to 'zmuser'@localhost identified by 'zmpass';"
sudo mysql -uroot
use zm;
ALTER TABLE Monitors modify column Type enum('Local','Remote','File','Ffmpeg','Ffmpeghw','Libvlc','cURL') NOT NULL default 'Local';
ALTER TABLE MonitorPresets modify column Type enum('Local','Remote','File','Ffmpeg','Ffmpeghw','Libvlc','cURL') NOT NULL default 'Local';
ALTER TABLE Controls modify column Type enum('Local','Remote','Ffmpeg','Ffmpeghw','Libvlc','cURL') NOT NULL default 'Local';
alter table Monitors modify column Function enum('None','Monitor','Modect','Mvdect','Record','Mocord','Nodect') NOT NULL default 'Monitor';
11. Install the modified zoneminder.deb. Hopefully postinst completes with no issue.
sudo dpkg -i ./zoneminder.deb
sudo dpkg --remove --force-remove-reinstreq zoneminder
sudo chmod 740 /etc/zm/zm.conf
sudo chown root:www-data /etc/zm/zm.conf
sudo ufw allow http
sudo chown -R www-data:www-data /var/cache/zoneminder/
Edit /etc/zm/zm.conf and add
ZM_PATH_SWAP=/tmp
sudo service zoneminder restart
* Add New Monitor
Select Ffmpeg and Mvdect for software h264 decoding via ffmpeg with motion vector extraction.
Select Ffmpeghw and Mvdect for hardware h264 decoding via ffmpeg using mmal and motion vector extraction via hardware mmal h264 encoder.
Software Scaling is used when source=Ffmpeg Function=Modect|Mvdect
Software Scaling is used when Source=Ffmpeghw Function=Modect
*For an sv3c camera, the settings are:
Source path = rtsp://mysv3c.chris.net/12
Remote Method = TCP
Capture width = 640
Capture height = 360
Source path = rtsp://mysv3c.chris.net/11
Remote Method = TCP
Capture width = 1280
Capture height = 720
***I could only test with one camera but in theory, it should be able to run multiple cameras. Just keep an eye on memory consumption. The kernel uses 25% of the 1GB RAM already, and with 256 MB set aside for GPU MEM, that leaves ~500 MB for all the cameras, mysql and any other running processes.
My current system is a PI3B with 16GB SDCARD. I don't have a hard disk attached so the jpegwriter, mp4writer and mysql are writing to the SD card.
* Define the Zone settings for this camera.
Click the Zones associated with the Monitor and Select Alarm Check Method as "AlarmPixels"
by macroblocks to label the frame as motion detected. Its an all or none score.
***The logic of the motion vector score calculation:
The Min Alarmed Area is taken as a percentage value of the polygon total area. Each vector is weighted as having equivalent of 16x16 pixels and each vector is given 4x weight, meaning a 25% pixel coverage is considered 100% coverage. The full frame will be tested so should give meaningful scores. The alarm centre is not being calculated at this time.
My Settings:
Camera is set at 15 fps on its web UI. //Lower this value to solve problems with buffer overruns.
Source Type = Ffmpeghw
Function = Mvdect
Enabled = checked
Reference Image Blend %ge = No Blending
Alarm Reference Image Blend %ge = No blending (Alarm lasts forever)
Remote Method = TCP
Target Colorspace = 24 bit color
Capture width = 640
Image Buffer size = 20 // Since I started using an external USB drive for storing events, this number has seemed adequate
Warm Up frames = 0
Pre Event Image Count = 1 //All JPEGs are created in the capture process.
Post Event Image Count =60 //increase to have longer events instead of many short ones
Stream Replay Image Buffer = 200
Alarm Frame Count =1 //1 alarm frame is alert only, 2 alarm frames mean record the event as an alarm.
Storage Tab:
Save JPEGs: Frames only.
Video Writer: H264 Camera Passthrough
Zoneminder Config
WATCH_MAX_DELAY = 10
WATCH_CHECK_INTERVAL = 20
OPT_ADAPTIVE_SKIP = checked
CREATE_ANALYSIS_FRAMES = unchecked
13. Optimizations
* Select high bitrate rtsp stream. I think this reduces encoding artifacts that might be seen by the mmal encoder as motion.
* No need to blend the image because we don't use pixel analysis. This greatly reduces zma's cpu utilization.
Set Reference Image Bled %ge to No Blending.
Set Alarm Reference Image Blend %ge to No blending.
*Edit Monitor Options and under Buffers (Image Buffer Size) increase to a higher number
*Uncheck Create_Analsyis_Images
*Adjust WATCH_MAX_DELAY if it keeps restarting zma.
*Set Warm-Up Frames to 0 since we dont need to generate a reference image.
*Use a fast hard disk to ensure jpeg writing and mysql writes don't delay zma and video storage writes don't delay zmc.
*Disable any debugging or logging options not needed in the Logging tab of Options. .
Other Optimizations (dont't know if relevant):
?In Options config OPT_ADAPTIVE_SKIP needs to be checked
?Set Analysis Update Delay
<From Google> Currently, video analysis is performed at full framerate, this can lead to high cpu load.
In order to reduce the cpu load, this PR add an analysis interval parameter to monitors settings.
Default value is 1, all images are processed.
If a greater value is set, for example 5, only images with count multiple of 5 will be processed.
The reason for this is to make it possible to reduce CPU-load if split-second motion detection is not required.
?Set Motion Frame Skip
<From Google> There is a new setting "Motion Frame Skip" under the "Misc" tab in the Monitor settings where you configure the value.
The default value is 0, so the feature is not active by default.
The feature works like Frame Skip. That is, if the value is "5" every 6th image will be analyzed for motion. The reference image is updated every frame to not change the effect of current blend settings.
14. Building the zoneminder deb
*Install the necessary packages for building
sudo apt-get install ccache
sudo apt-get install build-essential fakeroot devscripts
sudo apt-get install libnetpbm10-dev
sudo apt-get install libvlccore-dev
sudo apt-get install libgcrypt11-dev
sudo apt-get build-dep zoneminder
git clone https://github.com/cmisip/ZoneMinder.git
cd ZoneMinder
Due to the changes above, there are some UI issues that have not been fixed yet. The zones page on the web UI displays the downscaled frame but the zone polygon is displayed at full resolution. Setting the video resolution to 640x360 fixes the UI issue but adjusting the zone polygon may cause a segfault. I think the web interface is communicating with zoneminder via database and so does not know of the adjustments to resolution and polygon coordinates. Text annotation on jpeg does not work on the capture side jpegs. The jpeg display in the Event window now includes pixel arrows to show the direction and clustering of motion vectors which would be useful in developing a scoring system. It is turned on in the code so performance will suffer a little.
git checkout master
cp -rf distros/debian ./
git submodule update --init --recursive
sudo apt-get update
* Build the package.
cd cmake
cmake ../
cd ..
debuild --prepend-path=/usr/lib/ccache -us -uc -b
This is about 4000 commits behind zoneminder master so it will look and work differently than the most recent builds.
1. Frames jumping back in time or skipping. This might be due to an overburdened system where the capture and analysis components are being restarted by zoneminder. If you can avoid buffer overruns, this should be minimized. This doesn't matter if you use the video capture module as the event display will playback the mp4 at full resolution.
2. Alignment trap might show up here and there.
3. I have done all this work on the arm natively and so probably won't compile on X86.
4. Software motion vector code has been removed for now.
5. The resolution you put in the monitor setup screen may not matter because the video resolution is autodetected by avcodec and it will be downscaled to 640x360 anyway internally. The recorded jpegs will be at 640x360 but the recorded mp4 video will be in full resolution.
Here is the speed test with one rtsp stream at 640x360 with buffer visualization turned on at 15 fps source.
PIDSTAT zmc : Reporting average of 12 readings at 5 seconds intervals
ZMC Process ID : 27301 ==> ( 15.40 + 14.60 + 14.00 + 14.20 + 13.40 + 12.80 + 13.20 + 13.20 + 12.20 + 13.00 + 12.80 + 13.60 ) / 12
AVERAGE : 13.53
PIDSTAT zma : Reporting average of 12 readings at 5 seconds intervals
ZMA Process ID : 27305 ==> ( 5.40 + 1.40 + 0.20 + 0.00 + 1.40 + 2.80 + 4.20 + 1.60 + 2.40 + 0.40 + 0.00 + 3.20 ) / 12
AVERAGE : 1.91
Tasks: 128 total, 2 running, 82 sleeping, 0 stopped, 0 zombie
%Cpu(s): 3.3 us, 4.2 sy, 0.0 ni, 80.8 id, 11.6 wa, 0.0 hi, 0.1 si, 0.0 st
KiB Mem : 604356 total, 41972 free, 155468 used, 406916 buff/cache
KiB Swap: 102396 total, 52220 free, 50176 used. 345532 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
27301 www-data 20 0 285124 51852 43556 R 13.8 8.6 0:28.61 zmc
27305 www-data 20 0 237468 45552 38584 S 3.0 7.5 0:04.64 zma
27372 pi 20 0 8448 3084 2560 R 1.6 0.5 0:00.20 top
754 mysql 20 0 639116 43456 9096 S 1.3 7.2 2:15.32 mysqld
If there is an expert here with regards to figuring out memory issues, I would appreciate some assistance with the code. Have Fun.
Thanks,
Chris
https://notabug.org/monitor/ZM_rpi3_HWACCEL_Testing
- ZM 1.31.44 has HWACCEL if libavcodec-dev includes mmal or other hwaccel (not used in a binary ffmpeg or anything of that sort, though binary ffmpeg can use mmal for encoding afterwards)
- HWACCEL can be verified to be working by setting debugging on zmc_m#
- The HWACCEL calls are in zm_ffmpeg_camera.cpp see code for the debug string you are looking for
- Only SD resolution worked for me. I was unable to get 1280x720. 640x480 works, and works as well as MJPEG in terms of CPU.
I'm sure there is a limit to how many cameras, and what FPS this can do, so I'll be doing some more testing and will update the repo. Overall, I don't think the RPI is a strong ARM board (HD is not working for me). It's likely what was posted here is betterviewtopic.php?f=36&t=27020, but the RPI has a niche use, for some number of SD cameras, and they are common and cheap.
I might try adding an RPI to my existing server setup as an accessory server. Overall, I've found ARM boards to be untrustworthy when it comes to real processing grunt, and the RPI follows this trend, but I can't speak for the ODroid boards linked above.
