Hi there,
Can anyone suggest how I can do that?
I would like to try 5/12.
1/2 view does not fit the screen in 3 rows
1/3 leaves unused space.
your advice appreciated.
Adding custom scale into "Montage" view
Re: Adding custom scale into "Montage" view
Here is how to add "5/12x" to the montage stream view size selection:
open /usr/share/zoneminder/www/skins/classic/includes/config.php
and change this code starting around line 33 from:
to ->
then open your montage viewer and the size should be there in the selections.
$scales = array(
"400" => "4x",
"300" => "3x",
"200" => "2x",
"150" => "1.5x",
"100" => translate('Actual'),
"75" => "3/4x",
"50" => "1/2x",
"33" => "1/3x",
"25" => "1/4x",
"12.5" => "1/8x",
$scales = array(
"400" => "4x",
"300" => "3x",
"200" => "2x",
"150" => "1.5x",
"75" => "3/4x",
"50" => "1/2x",
"41" => "5/12x",
"33" => "1/3x",
"25" => "1/4x",
"12.5" => "1/8x",
Thanks a lot for your help!
Great tip!
