i have Zoneminder 1.30.4 running on a Ubuntu 16.04 maschine.
The camera i want to connect is a Foscam FI9928P.
As first step i only want to get the pictures/stream from the camera.
At the moment i have the following settings:
- General, Server: None
- General, Source Type: Ffmpeg
- General, Function: Monitor
- General, Enabled: checked
- Source, Source Path: rtsp://[USERNAME]:[PASSWORD]@[IP-ADDRESS]:[PORT]/videoMain
- Source, Remote Type: TCP
The link i'm using as "Source Path" is working when i use it in VLC player to play the stream.
When i open the window in Zoneminder to see the stream, only the events of the camera are shown, not the stream.
Does someone know why or what i should check?
Setting up Foscam FI9928P
Re: Setting up Foscam FI9928P
IMPORTANT FINAL STEP: Open Zoneminder in a web browser (http://server-ip/zm). Click on Options - Paths and change PATH_ZMS to /zm/cgi-bin/nph-zms
Can you try the nearest config model available below.
https://wiki.zoneminder.com/Foscam_FI9903P
Hope it's will help a bit. I still working with model FI8928W but still no success.
