I just noticed that the upper left link that enables to create camera groups is not working. By having a look into the index.html file, look like there's a missing link (not an expert here, so maybe I'm wrong!):
<div id="monitorSummary"><a>6 Monitors</a></div>
So, the link acts as a link, but when the mouse hovers over it, does not allow to "click" it. Is it a know bug or a problem in my system?
I'm using ZM 1.31.1~20170802162943-trusty.
Thanks in advance,
PacoLM
EDITED: Gave permissions to myself in the user options to edit groups...
[SOLVED]Group cameras link does not work in ZM 1.31.1
Re: [SOLVED]Group cameras link does not work in ZM 1.31.1
Editing groups and Selecting groups are both on the same permission setting?
RFE!!
RFE!!
one could modify the php code to further detail the permissions logic.
viewtopic.php?p=100570#p100570
Thanks for the pointer; I'll take a look at that.
