SOLVED/WORKING xmeye camera not working - VLC and BlueIris OK
Banderaz
Post by Banderaz »
Got this camera: http://www.ebay.com/itm/POE-720P-Mini-I ... Swux5YOpW5
I got it to work with VLC, streaming a RTSP stream with this URL: [url]rtsp://192.168.0.106/user=admin&password=mypassword&channel=1&stream=1.sdp[/url]
I also found it really quick in BlueIris, searching my local network, and it reported this: http://192.168.0.106:8899/onvif/device_service
In the log of BlueIris, it say this: RTSP URI: /user=admin_password=UnVGeZnB ... eal_stream
I tried all sorts of links, types etc in ZoneMinder, but no luck. ZM do not find it when I use Probe.
Running ZM v. 1.29.0 on my Unraid box, as a docker.
VLC reports 704/576 resolution, so used this in ZM.
Anyone got this type of camera to work? Shout out :) They are cheap, POE and appears to be with good picture quality.
Thank you
mun7
Re: xmeye camera not working - VLC and BlueIris OK
Post by mun7 »
Hey there!
I've got an Xmeye camera as well and running into the same issue - did you manage to find a fix?
Cheers
Banderaz
Post by Banderaz »
Been a long time since I tried this, but just got back to try today.
Notice that ZM now is reported as 1.30.4 so that might be the thing that made this WORK!
In the first picture, the "LINK HERE" is /user=admin&password=PASSWORD&channel=1&stream=1.sdp
Skjermbilde 2017-09-29 kl. 23.18.09.png (134.55 KiB) Viewed 4675 times
green link :)
green link :)
Skjermbilde 2017-09-29 kl. 23.18.25.png (83.08 KiB) Viewed 4675 times
Picture from under my desk :)
"proof of picture"
"proof of picture"
Skjermbilde 2017-09-29 kl. 23.18.43.png (966.01 KiB) Viewed 4675 times
Now I can buy more cameras :) Just around $37 it´s a real bargain!
