hello again
i use ubuntu server .. i have downloaded the libjpeg-turbo
how cam i check if zoneminder works with it
and how can i get zoneminder to use libjpeg-turbo with terminal commands??
i have found a lot of infos but not not exactly with the terminal commands
thx
how get zoneminder to use libjpeg-turbo?
Re: how get zoneminder to use libjpeg-turbo?
libjpg-turbo8 is installed with Zm 1.30.4
aha ok
then is this right?
if i enter: sudo lsof |grep libjpeg.so.8.0.2
i get:
zma 6677 www-data mem REG 8,2 363264 12065196 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.0.2
then it does not show ... libjpg-turbo8, only libjpeg.so.8.0.2
is this normal?
sorry i am an absolute ubuntu/zoneminder noob
then is this right?
i get:
is this normal?
