Newbie on zoneminder... running on a VM Debian 9.2.1, hosted on Esxi 6.5
Everything is OK
But (always a 'but')
I am not able to control my cams.
In the control tab, I'm not sure what to set exactly.
Address : I put a cam ip. Do I need to put the port as well like 192.168.1.10:81 or only IP
Type I select wanscam HW0025 but I edit it before as my cam are working that way :
For move up : /decoder_control.cgi?command=0&onestep=0&user=#username#&pwd=#password#
I've discovered this viewtopic.php?f=29&t=21198&p=80309&hili ... rol#p80309
So I modify like that but still don't work
Don't know where to check now... So if one of you can help. Will be much appreciated
Cheers
