I have a freshly installed Zoneminder v1.30.4 on CentOS EL 7. The web console works good and I have my monitor green. The things is that when I open the stream I get a blue screen with a time code on top.
Log states: Capturing at 1000.00 fps most of the time and then I get:
2017-11-01 16:24:13.074533 zmc_m1 1348 ERR Unable to open input rtsp://admin:claro2017@186.6.236.224:554/Streaming/Channels/101?transportmode=unicast&profile=Profile_1 due to: Operation now in progress
and:
getStreamCmdResponse stream error: socket_sendto( /var/lib/zoneminder/sock/zms-447100s.sock ) failed: Connection refused
The rstp stream works good on VLC (you can check it right now) but no luck with ZM. Also the IP is public by now without auth so you can check it out too (https://190.167.104.69/zm/index.php). I tried a lot of things so now I turn to the community to see if you can help me. These are screenshot of everything described. Hoping I get some support! Please!
