Stream works on web but not on ZMNinja
el_mechon_
Post by el_mechon_ »
Hello all.
I just installed v1.30.4 on CentOS7. Everything is working fine, I can see my stream and events. However, after purchasing ZMNinja isn't showing my monitors on iOS.
I used the wizard and also followed the F.A.Q. without success. I think the issue may be related to the cgi-bin path. Right now I have "/cgi-bin-zm/nph-zms" on the web server and the full path "https://190.167.104.69/zm/cgi-bin-zm" on ZMNinja. HTTP Auth is disabled. Please see attached screenshots.
If needed, I can provide remote access.
asker
Re: Stream works on web but not on ZMNinja
Post by asker »
Settings look ok. Any chance you can come online to irc.freenode.net channel #zoneminder so we can debug? Also, try to use the desktop version first (easier to debug) - once we fix it, we can fix mobile https://github.com/pliablepixels/zmNinja/releases
PS: Enable ZM Auth and just put a dummy username password (x/x) or something - and see if that helps
Please read before posting:
ES docs
zmNinja docs
el_mechon_
I tried the desktop app and got it working using the wizard. I looked at the path the wizard on the desktop app found and turns out the correct path to cgi-bin is "https://190.167.104.69/cgi-bin-zm" (notice the missing /zm). I placed that path on the mobile app and that fixed the issue.
I'm leaving this here for anyone having this problem.
asker, thanks for your quick response and support.
asker
Post by asker »
ok cool - glad you solved it!
ES docs
zmNinja docs
