I have a pretty much off the shelf ZM 1.30.4 install on Ubuntu.
I am not able to view any videos or see any recordings. I only see captured images and then still not able to view videos. I can if I download, but I they don't play in the browser. I have tried different browsers.
Also, when I click on any monitor (I have 15) I am not able to see the stream. I know that these are working as I actually view them in Home Assistant. However I want to use ZM for recording and this does not seem to be working. The path to web streaming I am using is /cgi-bin/nph-zms
I have not made many configurations at all (except basically adding the monitors and setup admin pwd)
Any ideas as to how I can view the videos when I go to the ZM UI in web browser?
No video, no recordings, only JPG's
Re: No video, no recordings, only JPG's
your configuration is most likely not correctly setup to reach /cgi-bin/nph-zms.
try going to Options->Paths->ZM_PATH_ZMS=/cgi-bin/nph-zms and adjust the path to =/zm/cgi-bin/nph-zms.
see if that works.
see if that works.
ah, brilliant! That did it! Thanks
