Hi all
I need to stand up a low cost CCTV. I've got a lot of "old" PC (AMD Athlon A64 for all of them) and a ML370 G5 Proliant server (8 cores w/ 2x Xeon X5450 and 32Gb RAM and 5 x 15K 72Go SAS HDD).
At the beginning, it was my old dual-core Athlon A64 X2 4400+ with 4Gb of RAM, a SSD for the OS and a RAID 0 of 2x250Go SATA HDD for recording.
I need 4 cams, outdoor, 3,5m from the ground. Motion detect need only, not recording permanently.
But, when I read that a core i7 is sometimes quite short, does I really need me Proliant server to built my own low-cost CCTV ?
Do you have some advices for good cheap outdoor ip camera also ?
Here a diagram I made : http://www.cjoint.com/c/GKsoQ3SYYqR
Thank's
Charles
Low cost cctv with ZoneMinder
Re: Low cost cctv with ZoneMinder
I'm confusing about decode, if I use my mid/high range graphic card (ati hd4580), may it help ?
Amazon.com on Nov 24th.
I found that camera : http://www.sv3cdeals.com/sv3c-full-hd-1 ... 30915.html
I gonna buy one for testing !
