[problem] Zoneminder several crash
Re: [problem] Zoneminder several crash
If you're lucky and your local host is Linux, then you should be able to run X11-applications (like software-properties-gtk) over network connection. You just have to start the remote session with ssh -X host instead of ssh host.
You can also add source support manually by editing file /etc/apt/sources.list directly. Unfortunately I have no detailed instructions for this!
I haved try with -x option but not working. (their is some line about wayland)
I need command line if anybody can help, this bug is really, really, really blocking. (so painful that I check for alternatives)
See this link for enabling downloading source code with apt:
https://askubuntu.com/questions/496549/ ... urces-list
Please note that lower case (small letter) option -x disables X11 forwarding. You have to use upper case (capital letter) option -X to enable X11 forwarding! See "man ssh" for more details.
Cheers
osk
I think i have drop the problem's source:
When the mariadb server (cluster) has a so big load, the database server fail.
I haved optimize the machine and, actually, the "bug" has dissipear.
Thanks for helping
Thanks for helping
