Hi
Is there anything I can do to track what is going on with montage as I am noticing at times it freezes frames and then doesnt catch up?
Is there any loging in zoneminder I can look at?
Montage Stop showing on screen
Re: Montage Stop showing on screen
The images in a montage are delivered by zms, which lives in the apache cgi-bin directory; you have have a zms log in /var/log/zm, and there may be something useful in the system log, too; what that is depends on how hard your distro managers tried to keep you from being Hammered By Lennart; usually /var/log/messages on RPMish distros, and /var/log/syslog on DEBish distros, and not there at all if your distro's release manager drank too much of the Flavor-Aid.
managed to get back on top of this and looked at the logs, noticed in the logs that "Try running 'zmupdate.pl -f' to reload config."
I have run it again to see if it fixes the issue.
would this error cause sporadic issues camera blanking?
