Question on status of Amazon S3 support
sypheXsquare
Post by sypheXsquare »
I apologize in advance if this is the wrong place to post, but I wanted to inquire about the current status of ZoneMinder and Amazon S3. I guess this would be a simple non-issue if you can dump a data directory to the cloud, but would probably be useful to someone technically inclined.
Re: Question on status of Amazon S3 support
I use it via s3fs. The lag is a problem.
So what I do is record locally and use a background filter to copy events to s3 storage.
kevrm
Post by kevrm »
Funny you mention this - I found a node.js based solution which was more work to get it working than to build one.. so I just built this:
https://github.com/CampsiteHelper/ZoneMinderS3
It uploads alarm image frames to s3 in short order. Allows me to do local full recording (MORECORD) and send relevant frame up for safekeeping.
Zmjm15
Post by Zmjm15 »
https://github.com/CampsiteHelper/ZoneMinderS3/
This looks pretty good,
Is it easy to get working?
Does it allow upload of all footage or just alarmed images? is there a way to choose a different email address for different cameras?
Many thanks
kevrm
Post by kevrm »
Zmjm15,
Its pretty easy to get working assuming you know how to setup an S3 bucket and permissions on AWS.
It only uploads alarm'd images.
I strongly doubt most most folks have upstream bandwidth to support uploading all images so I didn't build that in.
kevrm
Post by kevrm »
Been testing and improving, its working pretty well now
Zmjm15
Post by Zmjm15 »
Thanks Kevrm,
I want to set up a Raspberry pi with the camera module on it to put into my car, and then be able to upload alarmed images via 3g/4g, do you know if that is do-able?
