good afternoon!
Need help...
I have 1 camera wifi and wanted to hook it up to zoneminder. I removed the address from the ipsy and put it in the zoneminder, but the screen turns blue.
the zoneminder is installed on the raspberry.
in the photos are the settings and model of the camera
thank you
- camera.jpg (602.69 KiB) Viewed 3974 times
- zon.png (45.37 KiB) Viewed 3974 times
Re: the screen turns blue.
Camera resolution in Zoneminder does not match camera output. Use VLC (Tools, Media Information, Codec) to check camera Display Resolution.
the resolution is the same. Do not know what to do?
- zon.png (176.68 KiB) Viewed 3968 times
First try ffmpeg with the same data you used in VLC Location.
For remote host name use user:password@ipaddress remote host path use /snapshot.jpg
Use 32 bit colour
Note you may have to add a password to the camera to get it to work.
Use 32 bit colour
sorry but it's still the same
