timelyfiasco wrote: ↑Mon Feb 19, 2018 2:07 am
@Magic919
my ZM_PATH is /cgi-bin/nph-zms. There is a leading slash before images and events. I dont understand the last line. What is that?
@ bbunge
Yes, I mean multi server incase it matters. Im using debian 9.2.1. I followed
https://wiki.zoneminder.com/Debian_9_64 ... e_Easy_Way
BTW, all cameras are recording. and I can view live stream in montage. The problem only exist in using montage review.
I suggest reviewing the install instructions you used. I just ran them on Debian 9 and my montage review, with two USB camera, works.
If you, in fact, have two Debian servers running Zoneminder set up in a Multi Server operation you could have some permissions issues. While I've not done Multi Server on Debian I have on Ubuntu and the procedure should work for both. See:
https://wiki.zoneminder.com/Common_Issu ... _on_Ubuntu
You may also have a browser problem. If you are using Firefox you may need to adjust some settings in Firefox:
Enter about:config in the address bar
scroll down to
browser.cache.check_doc_frequency 3
change the 3 to a 1
browser.cache.disk.enable True -> False
network.http.max-connections-per-server -> put a value of 100
network.http.max-persistent-connections-per-proxy -> 100 again
network.http.max-persistent-connections-per-server -> 100 again
Restart Firefox
