State go to Inactive
jamigf
Post by jamigf »
Hi I have a Zoneminder 1.31.1 running.
All works but after some minutes of hours the state of zoneminder go from running to inactive and I cannot see the live from cameras??
Can you say me why this happen??
Thank you so much
Re: State go to Inactive
What does the log tell you? Did your server run out of memory?
jamigf
Post by jamigf »
It is possible the system go to inactive for load? I see the load go to over 8.0....
It is an intel atom 1.33Ghz 1 core...
the load is 8 with a single core CPU?? Wow..yes that does indicate something. Is the server memory is overflowing. what does the /dev/shm numbers look like?
jamigf
Post by jamigf »
/dev/shm is near 100%.....
so the problem is the Ram??
