Where did green dots in zone editor go
Just upgraded to 1.31.40. In the zoneeditor of 1.30.4 there were green dots that indicated the edge point of the polygon shape. these appear to have gone away in 1.31.40. This make editing the zone almost impossible. Is this a setting that can be turned back on? Or why did this go away?
Re: Where did green dots in zone editor go
Linux distro and version?
I'll second that. Ubuntu 17.10
Just did an install on Ubuntu 16.04 with the zoneminder-master PPA and everything works including the green dots you mention. Of course that is ZM 1.31.1.
Will try an upgrade to Storageareas.
OK, I got the same results with 1.31.40. Can't adjust the zone...
As a reminder this is development software. Expect some things to not work!
The dots are still there, just not visible. If you get your mouse in the right spot, the appropriate spot in the table will get highlighted.
Ok, I think there is more wrong here than I thought. I blame asker.
If you want to add this to your checklist
Monitor buttons graphics shifted
- monitor.jpg (30.47 KiB) Viewed 6733 times
Uh... mine doesn't have buttons in watch... uh oh..
Oh.. you only get them with StreamReplyBuffer... which I have turned off. Sigh.
Ubuntu 16.04 and storageareas 1.31.40
Updated to your new update and green dots are back.
Ba-dum-tish.
Controls - fixed in latest PR. dark skin is evil. Green dots - don't think I touched it.
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
