Zonminder installation on debian stretch dependencies
ovomaltin
Post by ovomaltin »
Within the installation steps http://zoneminder.readthedocs.io/en/lat ... ebian.html I have an issue in the installation of package zoneminder due to denpendencies problem:
apt-get install zoneminder
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
zoneminder : Depends: libavcodec56 (>= 6:11~beta1) but it is not installable or
libavcodec-extra-56 (>= 6:11.4) but it is not installable
Depends: libavformat56 (>= 6:11~beta1) but it is not installable
Depends: libavutil54 (>= 6:11~beta1) but it is not installable
Depends: libmysqlclient18 (>= 5.5.24+dfsg-1) but it is not installable
Depends: libswscale3 (>= 6:11~beta1) but it is not installable
Depends: php5-mysql but it is not installable
Recommends: libapache2-mod-php5 but it is not installable or
php5-fpm but it is not installable
Recommends: zoneminder-doc (>= 1.29.0+dfsg-1~bpo8+1) but it is not going to be installed
Recommends: ffmpeg but it is not going to be installed or
libav-tools but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
I am really not an apt expert so if someone can guide me on how to proceed to resolve those issue, that would be great!
Thanks,
OvO
Re: Zonminder installation on debian stretch dependencies
See the Zoneminder WIKI for Debian install instructions.
https://wiki.zoneminder.com/Debian_9_64 ... e_Easy_Way
