Unlisted events
juanmoura
Unlisted events
Post by juanmoura »
I updated all my ZM installations with the most current version (ubuntu server 16.04 LTS, with ZM 1.31.40).
After updated events appear if I click the monitor, listing below it.
But if I open a filter or click on the columns Days Weeks etc not list. It only shows one, but if I open the event I go forward or backward I can see the others.
https://imgur.com/a/3RsqQ
juanmoura
Re: Unlisted events
Post by juanmoura »
Searching in the log with ERR i see this.
https://imgur.com/a/ovoY0
juanmoura
Re: Unlisted events
Post by juanmoura »
I see the filter Purge When Full not working, my zabbix is show me the space <5%
Re: Unlisted events
You can run zmaudit.pl manually with the -f parameter to force it.
As to the events list, php is crashing after outputting the first line. Look further in logs
Re: Unlisted events
I think I found the issue with the events list. Fix pushed, building packages now.
juanmoura
Re: Unlisted events
Post by juanmoura »
Iconnor, worked out when I updated again, listed correctly again. I'll keep watching for zmaudit if it will return to error. Many thanks and congratulations for the system.
