hello everybody,
I want to install zm with "yum....", but This is what I got, do you have an Idea to pass this, thx
[root@localhost ~]# rpm --import http://atrpms.net/RPM-GPG-KEY.atrpms
[root@localhost ~]# yum -c http://www.computerntelecom.com/download/zm-fc3.repo install zm
Repository ctu-Extra-RPMS already added, not adding again
Repository updates-released already added, not adding again
Repository base already added, not adding again
Repository ctu-updates-released already added, not adding again
Repository ctu-base already added, not adding again
Setting up Install Process
Setting up Repo: ctu-updates-released
repomd.xml 100% |=========================| 951 B 00:00
Setting up Repo: ctu-Extra-RPMS
Setting up Repo: base
repomd.xml 100% |=========================| 1.1 kB 00:00
Setting up Repo: updates-released
Reading repository metadata in from local files
ctu-update: ################################################## 16/16
ctu-Extra-: ################################################## 32/32
base : ################################################## 2622/2622
updates-re: ################################################## 972/972
Excluding Packages in global exclude list
Finished
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Package zm.i386 0:1.21.3-1.0_FC3.root set to be installed
--> Running transaction check
--> Processing Dependency: lame for package: zm
--> Processing Dependency: libavformat.so for package: zm
--> Processing Dependency: perl-TimeDate for package: zm
--> Processing Dependency: libavcodec.so for package: zm
--> Processing Dependency: libmp3lame.so.0 for package: zm
--> Processing Dependency: perl-MIME-tools for package: zm
--> Processing Dependency: perl-MailTools for package: zm
--> Processing Dependency: perl(Device::SerialPort) for package: zm
--> Processing Dependency: perl-IO-stringy for package: zm
--> Processing Dependency: perl-Unicode-String for package: zm
--> Processing Dependency: perl-Unicode-Map for package: zm
--> Restarting Dependency Resolution with new changes.
---> Package lame.i386 0:3.96.1-10.rhfc3.at set to be installed
---> Package ffmpeg.i386 0:0.4.8-4.rhfc3.at set to be installed
---> Package perl-TimeDate.noarch 1:1.16-2 set to be installed
---> Package perl-MIME-tools.noarch 0:6.200_02-1.FC3 set to be installed
---> Package perl-MailTools.noarch 0:1.66-1 set to be installed
---> Package perl-Device-SerialPort.i386 0:1.002-1 set to be installed
---> Package perl-IO-stringy.noarch 0:2.109-FC3 set to be installed
---> Package perl-Unicode-String.i386 0:2.07-1 set to be installed
---> Package perl-Unicode-Map.i386 0:0.112-1 set to be installed
--> Processing Dependency: libfaad.so.0 for package: ffmpeg
--> Processing Dependency: faad2 for package: ffmpeg
--> Processing Dependency: imlib2 for package: ffmpeg
--> Processing Dependency: libImlib2.so.1 for package: ffmpeg
--> Processing Dependency: a52dec for package: ffmpeg
---> Package faad2.i386 0:2.0-2.rhfc3.at set to be installed
---> Package imlib2.i386 0:1.1.2-3.rhfc3.at set to be installed
---> Package a52dec.i386 0:0.7.4-6.rhfc3.at set to be installed
--> Processing Dependency: liba52.so.0 for package: a52dec
--> Processing Dependency: liba52_0= 0.7.4 for package: a52dec
---> Package liba52_0.i386 0:0.7.4-6.rhfc3.at set to be installed
Dependencies Resolved
Transaction Listing:
Install: zm.i386 0:1.21.3-1.0_FC3.root
Performing the following to resolve dependencies:
Install: a52dec.i386 0:0.7.4-6.rhfc3.at
Install: faad2.i386 0:2.0-2.rhfc3.at
Install: ffmpeg.i386 0:0.4.8-4.rhfc3.at
Install: imlib2.i386 0:1.1.2-3.rhfc3.at
Install: lame.i386 0:3.96.1-10.rhfc3.at
Install: liba52_0.i386 0:0.7.4-6.rhfc3.at
Install: perl-Device-SerialPort.i386 0:1.002-1
Install: perl-IO-stringy.noarch 0:2.109-FC3
Install: perl-MIME-tools.noarch 0:6.200_02-1.FC3
Install: perl-MailTools.noarch 0:1.66-1
Install: perl-TimeDate.noarch 1:1.16-2
Install: perl-Unicode-Map.i386 0:0.112-1
Install: perl-Unicode-String.i386 0:2.07-1
Is this ok [y/N]: y
Downloading Packages:
perl-TimeDate-1.16-2.noar 100% |=========================| 31 kB 00:00
warning: rpmts_HdrFromFdno: V3 DSA signature: NOKEY, key ID 4f2a6fd2
public key not available for ///var/cache/yum/base/packages/perl-TimeDate-1.16-2.noarch.rpm
