The whole point of mocord is to record frames even if there is no alert trigger, because the alert may not be sensitive enough and/or I may want to see things like the wind or sun moving or whatever doesn't otherwise trigger alerts.
However bulk is designed so that 100 frames that are the same, don't save 100 jpegs on my disk, and only save one to save me space.
However, bulk will also only record a frame every 30 to 100 or so seconds depending on my frame rate if the alert is not triggered, which means it doesn't really do what I need.
Am I correct that I need to set bulk frames to 0 and be ready for a lot more disk use if I want true mocord?
I am recording in 1080p+, so my frames seem to be around 300KB. At 1fps, that's 20MB per minute or 288GB per day per camera. Ouch, that would hurt.
So, I guess I'm either stuck with using bulk, or switching to H264 output, which is not supported by zoneminder, correct?
But if I keep things as is, I'm still confused as to how it works, please look at this:
Why do I have events as long as 36mn with 6608 frames, and then events with 1 second and 1 frame?
you can find a zoomed version here: http://www.awesomescreenshot.com/image/ ... 00b5023de3
