Camera pass through seems to work with trendnet cameras but not with dahua. Here is what I get in the log file:
Apr 23 15:18:29 zmtest zmc_m4[2507]: INF [zmc_m4] [Opening video storage stream /var/cache/zoneminder/events/4/2018-04-23/5211/5211-video.mp4 format: mp4]
Apr 23 15:18:29 zmtest zmc_m4[2507]: WAR [zmc_m4] [Unable to set movflags to frag_custom+dash+delay_moov]
Apr 23 15:18:29 zmtest zmc_m4[2507]: ERR [zmc_m4] [Error occurred when writing out file header to /var/cache/zoneminder/events/4/2018-04-23/5211/5211-video.mp4: Invalid argument#012]
Apr 23 15:18:29 zmtest zmc_m4[2507]: ERR [zmc_m4] [Got signal 11 (Segmentation fault), crashing]
Apr 23 15:18:29 zmtest zmc_m4[2507]: ERR [zmc_m4] [Signal address is 0x18, from 0x7f8b021e627c]
Apr 23 15:18:29 zmtest zmc_m4[2507]: ERR [zmc_m4] [Backtrace 0: /usr/bin/zmc(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x563cf757adf8]]
Apr 23 15:18:29 zmtest zmc_m4[2507]: ERR [zmc_m4] [Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7f8b0393a390]]
Apr 23 15:18:29 zmtest zmc_m4[2507]: ERR [zmc_m4] [Backtrace 2: /usr/lib/x86_64-linux-gnu/libavformat-ffmpeg.so.56(+0xd427c) [0x7f8b021e627c]]
Apr 23 15:18:29 zmtest zmc_m4[2507]: ERR [zmc_m4] [Backtrace 3: /usr/lib/x86_64-linux-gnu/libavformat-ffmpeg.so.56(av_write_trailer+0x2ff) [0x7f8b0220279f]]
Apr 23 15:18:29 zmtest zmc_m4[2507]: ERR [zmc_m4] [Backtrace 4: /usr/bin/zmc(_ZN10VideoStoreD1Ev+0x514) [0x563cf7597864]]
Apr 23 15:18:29 zmtest zmc_m4[2507]: ERR [zmc_m4] [Backtrace 5: /usr/bin/zmc(_ZN12FfmpegCamera16CaptureAndRecordER5Image7timevalPc+0xa2d) [0x563cf75e523d]]
Apr 23 15:18:29 zmtest zmc_m4[2507]: ERR [zmc_m4] [Backtrace 6: /usr/bin/zmc(_ZN7Monitor7CaptureEv+0x3a2) [0x563cf7536a02]]
Apr 23 15:18:29 zmtest zmc_m4[2507]: ERR [zmc_m4] [Backtrace 7: /usr/bin/zmc(main+0x904) [0x563cf750c954]]
Apr 23 15:18:29 zmtest zmc_m4[2507]: ERR [zmc_m4] [Backtrace 8: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7f8aff757830]]
Apr 23 15:18:29 zmtest zmc_m4[2507]: ERR [zmc_m4] [Backtrace 9: /usr/bin/zmc(_start+0x29) [0x563cf750f1d9]]
Apr 23 15:18:29 zmtest zmc_m4[2507]: INF [zmc_m4] [Backtrace complete, please execute the following command for more information]
Apr 23 15:18:29 zmtest zmc_m4[2507]: INF [zmc_m4] [addr2line -e /usr/bin/zmc 0x563cf757adf8 0x7f8b0393a390 0x7f8b021e627c 0x7f8b0220279f 0x563cf7597864 0x563cf75e523d 0x563cf7536a02 0x563cf750c954 0x7f8aff757830 0x563cf750f1d9]
Apr 23 15:18:29 zmtest zmdc[1769]: ERR ['zmc -m 4' exited abnormally, exit status 11]
Thanks,
1.31.42 Camera Pass through
Re: 1.31.42 Camera Pass through
Ok, found the problem. Audio codec must be set to AAC. Now only problem left is that after a zoneminder restart, the first event is viewable but not the subsequent ones.
Thanks,
Thanks,
I'd really like some more detailed logs, with debugging turned on.
Please set debug level to 4.
the code SHOULD re-encode whatever the camera sends to AAC. Works for my cameras that send pcm audio.
Pretty weird but it seems to be working now. I'll do more testing and try to figure out what solved it.
How did you set the audio codec to AAC? (camera or within zoneminder settings someplace)?
Hi, the setting was on the camera
thank you.. for some reason i am unable to get audio to work with unless it encode it into AAC using cmdline options.
