Layout messed up after 1.31.44 update
juanmoura
Re: Layout messed up after 1.31.44 update
Post by juanmoura »
I try filter inside the log for only zmdpkg and i see that.
juanmoura
Post by juanmoura »
any news??
amritgary
Post by amritgary »
In 1.31.44 (most recent build) zmdc.pl got changed causing the restartPending observed above.
zmpkg.pl spawns off zmdc.pl and then sequentially starts each of the zmc monitor processes as well as the background filter processes.
With the most recent change in zmdc.pl, it no longer passes back control to zmpkg.pl client following the 2nd zmc monitor, thus causing an infinite loop within zmdc.pl. Hopefully this gets fixed, meanwhile i've reverted back to 1.31.43..
elchavodel8
Post by elchavodel8 »
i have that message in logs restartpending too, also with 1.31.44 i cant restart zoneminder from console using service zoneminder restart. Its freezes and do nothing, rigt after the command i entr password and stays like that without restarting
asker
Post by asker »
iconnor has likely fixed it in the latest commits. Works for me.
Please read before posting:
ES docs
zmNinja docs
juanmoura
Post by juanmoura »
Yes, I updated and stopped as well, but I noticed that whenever I am updating I have to carry out the process of changing the Object to CakeObject in relation to api, otherwise it breaks.
amritgary
Post by amritgary »
Something is still broken. zmc process keeps restarting.
I have the same restart issue. I have 2 systems setup that are exactly the same OS and LAMP....one runs 1.30.4 the other 1.31.44 using the same network cameras. The first one the logs run green all day long....the 2nd has the restart issue.....zmc constantly terminating and restarting. I am looking to see if a PERL module is perhaps missing.
mathijss
Post by mathijss »
I'm using 1.31.44 from the master ppa and I don't have the restart issue anymore.
WHC
Post by WHC »
We had the same issues after the update. Thanks to the replies here we were able to fix the layout issues. However, we cannot get live video to work, either in a browser or zmNinja. The video is saved and can be seen when replayed. Any thoughts on this?
I set up the latest from the master branch and am not able to add a monitor. Options page missing Paths and has a lot of blank space at the top.
can you try an experiment and comment out the error_reporting line at the top of /usr/share/zoneminder/www/index.php?
then try to add a monitor....what happens?
Eradicator
Post by Eradicator »
Only me can't change monitor position in server list?
I can not change monitor position in the latest 1.31.44 either
tuxmos
Post by tuxmos »
Since 1.31.44 and the necessary conversion in zoneminder.conf for apache, I have no more thumbnails in the event view. Only when I move the mouse over the place where the thumbnail should actually be, then, as usual, the video / image sequence appears.
The changes in zoneminder.conf for apache of course I have made.
