[zm1.31.44] Filters not show / Not working
PacoLM
Post by PacoLM »
After upgrading my system to the latest & greatest version, the filters page is not shown (just a blank page is opened) and also, it seems they are not working.
Any clue?
Thanks in advance,
PacoLM
Eradicator
Re: [zm1.31.44] Filters not show / Not working
Post by Eradicator »
Hi!
Did you try reinstall ZM totally? I'm tested 1.31.44 (last build) on Ubuntu 16.04.4 and 18.04, both works good. Purge and diskspace filters works correctly.
There is a known issue with really old php. Should be fixed now in master.
PacoLM
Post by PacoLM »
Eradicator wrote: Mon Jun 04, 2018 6:46 am Hi!
Reinstalling everything is the Windows approach, I prefer to fix it! ;)
Regards,
PacoLM
Eradicator
PacoLM wrote: Wed Jun 06, 2018 6:41 pm
Regards,
PacoLM
I'm testing zm long time ago. Sometimes there was an errors which fixed with clean reinstall. But sometimes it can be fixed by hands. :wink:
PacoLM
Post by PacoLM »
Eradicator wrote: Thu Jun 07, 2018 8:49 am
Regards,
PacoLM
I have been using Zoneminder for almost 10 years, I know it... ;)
Regards,
PacoLM
