login stopped working
alexl
Post by alexl »
My login admin/admin all the sudden stopped working.
How do I fix it or disable it all together?
I'm using FC3 based zm.
Please help.
Alex
zoneminder
Site Admin
Post by zoneminder »
Have you recently upgrade php to version 4.4 as that seems to have broken something in ZM. It's currently under investigation.
Phil
alexl
Post by alexl »
No, I didn't touch it...
Can you please point me out to the file with the login.
Alex
alexl
Post by alexl »
Just want to clarify that I recently upgraded to Wendows Me -
thats when I start to expirience this problem.
Alex
zoneminder
Site Admin
I don't think going to Me would make much difference. To disable logins entirely you can do
perl zmconfig.pl ZM_OPT_USE_AUTH
in the build directory. This should just switch them off while the problem is investigated further.
Phil
alexl
Post by alexl »
Phil,
thank you very much for your help - you are correct,
Me has nothing to do with it.
Now, how do I get into build directory?
Truly, Alex
alexl
Post by alexl »
Am I supposed to rebuild something once I make a change in a build directory?
Alex
cordel
Post by cordel »
If your using my distro you will have to change it in the database.
mysql zm
UPDATE Config SET Value='0' WHERE Name='ZM_OPT_USE_AUTH';
exit
This should be done loged in as root.
Regards,
Cordel
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
alexl
Post by alexl »
Ok, will give this a try!
Alex
alexl
Post by alexl »
It worked, but databaces got corrupted again - Ifound it out after login.
NMay be to reinstall the software?
How to get a new cd from you?
Alex
cordel
Post by cordel »
Sorry about the CD, I have it burned I just have to load it and make sure I didn't break anything. I'll check it out tonight.
Regards,
Cordel
