Zoneminder Capture Failing
mgranger
Post by mgranger »
So I have 4 cameras set up to use Mocord. I am using the unraid docker of zoneminder. My server has 32 GB of RAM of which I am sharing 65% of it for Zoneminder. I have noticed that two of my cameras are failing to capture correctly. I keep seeing black screens every so often so i looked into it a bit an these two cameras seem to be recording more events than the other two. I assume this is happening because they are coming back and starting a new event each time they crash whereas the other two record the whole event but I can't figure out why. I will attach my log file. The two cameras are South Cam Day and Driveway Cam Day.
zm-log.txt
(927.79 KiB) Downloaded 198 times
Re: Zoneminder Capture Failing
I'm going to suggest you switch to the ffmpeg monitor type. It looks like our not handling audio packets is causing the problem.
mgranger
Post by mgranger »
That worked perfectly. Thanks for the help.
