Hi all,
Hopefully there is someone who can help me out here.
I am fairly new to zoneminder bu I am already hooked. I got my first camera up and running and its working like a charm.
I've read a lot of things about setting up filters that start a script but I have no ide how to set this up.
I set a filter that when detection is noticed a scripts needs to be run towards domoticz.
the idea is to set a virtual switch when zoneminder is sees movement.
The curl that needs to be run is as follows:
curl http://DOMOTICZIP:PORT/json.htm?param=switchlight&type=command&idx=58&switchcmd=On
can someone tell me how to set this up?
thanks in advance!
script towards domoticz
Re: script towards domoticz
ok, from CLI I got it working. its now a matter of activiting it via the filter settings.
hopefully there is someone who is able to help.
thanks anyways
thanks anyways
I have solve it with zmeventserver. It´s a bit overloaded for my things to do but it works. I use it to trigger ioBroker.
Install an configure it like the README.
After install and make sure zmeventnotification.pl is working without errors, modify that file at line 504 right after @push_events.....
Insert a line like
$mid is the Camera ID in my case.
Of course you can make more lines for more cams after that.
Hope it helps.
Insert a line like
if ($mid == 1) { system('wget -q http://192.168.0.1:8082/set/javascript.0.CamMotionDetected?value=true'); }
Hope it helps.
