Console shows incorrect event counts
maskott
Post by maskott »
I am trying to get Zoneminder running in a docker container, and I've had this instance up for a few weeks now... I just noticed that the event counts listed on the Console are the same for each time period. What weird configuration have I enabled? Or is this a bug?
Screenshot 2018-09-13 14.14.00.png (58.85 KiB) Viewed 39219 times
Re: Console shows incorrect event counts
This would be a misconfig I think. I suspect that either a db update failed or zmstats.pl is not running.
al.semenenko88
Post by al.semenenko88 »
I see the same thing. It uses lxc to proxmox. After upgrading to 1.31
al.semenenko88
iconnor wrote: Thu Sep 13, 2018 9:51 pm This would be a misconfig I think. I suspect that either a db update failed or zmstats.pl is not running.
yes, zmstats.pl is not running.
maskott
Post by maskott »
How would one go about making sure that `zmstats.pl` runs automatically in the docker instance? Or how to start it manually?
