ZM image streaming fails with Microsoft Edge
Bloodrule
Post by Bloodrule »
I'm running zm 1.30.4 and live streams are working for each camera and in montage view when I use Google Chrome as browser. With Microsoft Edge, the images display but are frozen in time ie not streaming. Are there settings in Edge or in zm that I need to configure to enable the jpegs to stream?
Re: ZM image streaming fails with Microsoft Edge
Sure, switch to Firefox.
Used to be with Microsoft browsers you needed Java on the pc and cambozola on the zm server. So Firefox is the better bet.
Bloodrule
Post by Bloodrule »
Thanks. I already use Chrome on other devices and know that Firefox is good too. The particular reason for my question was that I now have a Microsoft Surface Go which runs Windows 10S. This protected OS only has Edge. I'm aware that I can do a once-only and irreversible upgrade to Windows 10 Home but I'm trying to see how far I can get in the Windows 10S world for the time being as I'm assuming the upgprade to Home will come at a cost of performance, battery life and, probably, security.
Hence the question about Edge.
Bloodrule
Post by Bloodrule »
So there's no way to stream to Edge?
