404 not found
sadams54
404 not found
Post by sadams54 »
I just did update and zoneminder updated to 1.32. I ran the database updates and I think it is running but no web access at all. I get 404 /zm not found. Please help me fix this.
doubleosix
Re: 404 not found
Post by doubleosix »
I get the same error after upgrading from 1.30.4 to 1.32.0. I ran "sudo systemctl status -l zoneminder" and it told me to to run the "zmupdate.pl" but the update script hangs at version 1.31.11
tigerA
Re: 404 not found
Post by tigerA »
For new version 1.32.
In folder /etc/zm/www there is a file zoneminder.conf. Copy this file in /etc/httpd/conf.d and restart httpd service.
sadams54
Re: 404 not found
Post by sadams54 »
thank you so so so so so much. that worked. I do not care for the new interface tho
