Adding sound on server-side
What is the simplest way to add sound playing on event, but on the server ?
I'm not sure I understand what you mean but, Phil is doing work on having ZM capture sound to go with the captured images so that ZM records sound and images. My understanding is that this should be available in the next couple major release versions so hopefully by the end of the year. No promisses though. If this is not the answer your looking for you'll need to elaborate please.
Regards,
Cordel
Regards,
Cordel
