Doesn't work with Ubuntu Bionic 18.04
johnaaronrose
Re: Doesn't work with Ubuntu Bionic 18.04
Post by johnaaronrose »
I can see the camera's picture using vlc with Network Stream of http://212.170.22.153:8080/mjpg/video.mjpg
John
johnaaronrose
'sudo service zoneminder status' gives:
Oct 30 18:58:03 Laptop zmdc[1263]: INF ['zmc -m 1' starting at 18/10/30 18:58:03
Oct 30 18:58:03 Laptop zmdc[12066]: INF ['zmc -m 1' started at 18/10/30 18:58:03
Oct 30 18:58:03 Laptop zmwatch[1460]: ERR [Memory map file '/dev/shm/zm.mmap.2'
Oct 30 18:58:03 Laptop zmwatch[1460]: INF [Restarting capture daemon for Test, s
Oct 30 18:58:03 Laptop zmdc[1263]: INF ['zmc -m 2' starting at 18/10/30 18:58:03
Oct 30 18:58:03 Laptop zmdc[12070]: INF ['zmc -m 2' started at 18/10/30 18:58:03
Oct 30 18:58:03 Laptop zmc_m1[12066]: ERR [Can't run query: Unknown column 'Anal
Oct 30 18:58:04 Laptop zmc_m2[12070]: ERR [Can't run query: Unknown column 'Anal
Oct 30 18:58:04 Laptop zmdc[1263]: INF ['zmc -m 1' crashed, signal 138]
Oct 30 18:58:04 Laptop zmdc[1263]: INF ['zmc -m 2' crashed, signal 138]
John
Looks like you have an issue with your memory. You need more in /dev/shm that is why you have an error.
johnaaronrose
I've upgraded memory on laptop from 4GB to 8GB. System Monitor shows that 5.3GB is being used out of 7.7GB, with no Swaop memory being used. But still same problem with ZM: Firefox screenshot attached.
John
johnaaronrose
I forgot to show problem with zoneminder using 'sudo service zoneminder status':
Nov 01 17:05:06 Laptop zmdc[1281]: INF ['zmc -m 1' starting at 18/11/01 17:05:06
Nov 01 17:05:06 Laptop zmdc[16966]: INF ['zmc -m 1' started at 18/11/01 17:05:06
Nov 01 17:05:06 Laptop zmwatch[1644]: ERR [Memory map file '/dev/shm/zm.mmap.2'
Nov 01 17:05:06 Laptop zmwatch[1644]: INF [Restarting capture daemon for Test, s
Nov 01 17:05:07 Laptop zmc_m1[16966]: ERR [Can't run query: Unknown column 'Anal
Nov 01 17:05:07 Laptop zmdc[1281]: INF ['zmc -m 2' starting at 18/11/01 17:05:07
Nov 01 17:05:07 Laptop zmdc[16970]: INF ['zmc -m 2' started at 18/11/01 17:05:07
Nov 01 17:05:07 Laptop zmc_m2[16970]: ERR [Can't run query: Unknown column 'Anal
Nov 01 17:05:07 Laptop zmdc[1281]: INF ['zmc -m 1' crashed, signal 138]
Nov 01 17:05:07 Laptop zmdc[1281]: INF ['zmc -m 2' crashed, signal 138]
John
