comments and views on hardware selection
Airwolf
Post by Airwolf »
Hi everyone - now i have a working and stable version of ZM on FC3 i am thinking of upgrading my single, low spec camera.
I have investigated a bit and read some of the entries on this forum regarding capture cards and cameras.
I intend to only have a max of 4 cameras, over time.
Q. can i get away with a 4 port 1 chip card or do i need a 4 port 4 chip version? the former are readily available and cheap on eBay.
Q. what do you recommend wireless or wired cameras, B&W or colour/ B&W @ night.
I have limited funds available for this.
thanks for your help
jameswilson
Post by jameswilson »
i would go with the single chip card as you will make a huge saving here. Also you will get about 2 fps accross all 4 inputs so will keep hard disk and proc/ram etc req down. Camera wise depends on scene etc. I currently rin a colour med res, mon med res and day night with IR obviously the day night is best but the most expensive. If light is an issue maybe security lighting and colour cams or else just go with mono but they will require some light. Let me know what your planning on viewing, expected ligh levels etc. Oh and wired all the way
James
Airwolf
Post by Airwolf »
Hi James
Thanks for your tips. I think B&W, med res will probably be OK. Of my 4 areas, only 1 has poor light. The other 3 have sufficient street lighting so B&W with LEDS will probably be OK.
jameswilson
if you ave sufficient light for you to be able to see clearly mono cams with a low f stop lens should be ok without additional lighting. In your one with poor light use ir leds there
