Gapless Events - Fast Forward reverts back to 1x for each new event
c128
Post by c128 »
I've been running 1.32.2 on a test server, and after a successful period of running there's now only one thing stopping me switching over my main server from 1.30.4.
When viewing "Gapless Events", if I set a Fast Forward speed on one event it always reverts back to 1x when it hits the next event - makes it quite difficult to review a range of events at a higher speed, as I often do with 1.30.4, as the speed I have set is forgotten.
Is this a settings mistake my side?
Thanks.
c128
Re: Gapless Events - Fast Forward reverts back to 1x for each new event
Post by c128 »
Anyone else seeing this, or is it just an oddity of my install?
It's quite a pain to review multiple (gapless) events when the speed drops back to 1x on each new event.
Pedulla
Post by Pedulla »
I've seen it to, but only on h264 recordings.
The old MJPEG work as they did.
c128
Post by c128 »
Ah, yes, that's a good point- I am making use of h.264 too.
There's also the "black flash" that you get between events, but I can live with that - the resetting of the speed is a bit of a problem when reviewing events though :(
Alec
Post by Alec »
I experience this also, saving only h.264. And I agree that it would be an improvement to keep the playback speed from event to event.
DFU
c128
Post by c128 »
Given that I guess this isn't expected behaviour, as it doesn't work this way for non-h.264 stored files, I've raised a bug here https://github.com/ZoneMinder/zoneminder/issues/2319.
krejler
Post by krejler »
+1 for this one, its anoying that its getting reset after each new event.
c128
Post by c128 »
Just seen that this has been fixed on Github for the next release - thanks chaps :D .
LBDG
Post by LBDG »
This fix maintaining set speed after each new event is great. Thank you
However I noticed that on my system (connor ppa stable 1.32.3) the set speed resets within an event when clicking the progress bar. I am not sure if this is the intended function but It would be beneficial if the set speed within the event remained fixed.
Thanks all contributors for this great piece of software.
c128
Post by c128 »
Actually, I've just upgraded to 1.32.3 from the PPA, and I don't see any change in behaviour from the original defect (regardless of clicking in the progress bar) i.e. when viewing gapless events, and "upping" the rate, it still resets to 1x on the next event.
c128
Post by c128 »
Yeah, I've just checked - post-upgrade to 1.32.3 I do have the changes in place from the commits listed in https://github.com/ZoneMinder/zoneminder/issues/2319 , but also the initial original issue...
Alec
Post by Alec »
Same here. Still resets to 1x on new event.
Also, for me, in the progress bar banner the zoneminder event timestamp is static with the event start time stamp. Previous beta versions showed the dynamic time of the frame being viewed in the progress bar banner. Not sure if this is related . . .?
DFU
1.32.3 was a slight improvement but still does not entirely fix the problem, as many of you have noted.
I have pushed some additional fixes to master which will go in the next release.
