OS: Linux Gentoo
Web server: Apache
Note: I am aware that building Zoneminder from sources is discouraged, however, the latest version of Zoneminder available for installation in Gentoo portage is 1.30.4 and it is completely unusable with fully updated Linux Gentoo system (it segfaults). https://forums.gentoo.org/viewtopic-t-1084192.html.
So, I obtained sources from github and successfully compiled Zoneminder. It works perfectly fine. There are no problem with build or installation.
The CORS issue I am running into is related to the fact that I am using three different servers to host cameras.
The main server that runs the Web interface
example.com
a.example.com
b.example.com
c.example.com
(Reason: CORS request did not succeed).
SyntaxError: "JSON.parse: unexpected character at line 1 column 1 of the JSON data"
decode https://example.com/tools/mootools/mootools-core.js:6672:26
success https://example.com/tools/mootools/mootools-core.js:6717:32
wrapper https://example.com/tools/mootools/mootools-core.js:1723:16
onStateChange https://example.com/tools/mootools/mootools-core.js:6291:4
bind https://example.com/tools/mootools/mootools-core.js:993:11
https://a.example.com/index.php?view=request&request=status&entity=events&id=2&count=20&sort=Id%20desc.
I tried using the config file from https://github.com/ZoneMinder/zoneminde ... -cors.conf but the error still persists (I did adopt config for my installation).
What can be done to solve it?
