Outline/Box around detected motion
Tomm
Post by Tomm »
I had the outline of detected motion active in 1.30, now that i migrated to 1.32.3 i can't get it to work.
For motion frames, there is only a red square around the frame border, but nothing indicating the alarmed blobs.
I have the "Options>Config>CREATE_ANALYSIS_IMAGES" enabled.
Here's the zone :
Name	Terras
Type	Active
Units	Pixels
Alarm Colour (Red/Green/Blue)	255 /  0 /  0
Alarm Check Method	Blobs
Min/Max Pixel Threshold (0-255)	80 255
Filter Width/Height (pixels)	5 5
Zone Area	499673
Min/Max Alarmed Area	160 50000
Min/Max Filtered Area	130 0
Min/Max Blob Area	130 0
Min/Max Blobs	1
Overload Frame Ignore Count	0
Extend Alarm Frame Count	0
What am I missing ?
Tomm
Re: Outline/Box around detected motion
Post by Tomm »
can I add some info, to get more traction in this forum ?
Tomm
[SOLVED] Outline/Box around detected motion
Post by Tomm »
I found what was causing the lack of analysis frames.
MJN
Post by MJN »
Can you share what it was to help others with the similar issue that might stumble across this thread?
SkippyDo
Post by SkippyDo »
