I've got ZoneMinder and Home Assistant running on the same PC. I've followed the integration instructions in Home Assistant for ZoneMinder. This should allow me to view the image that ZoneMinder is seeing/recording and some sensors off the IP camera. So far when I look at Home Assistant for the camera image all I have is a broken link to the image. I've checked the logs for both products and I can't see anything wrong.
Does anyone have any suggestions?
Thanks!
ZoneMinder integration with Home Assistant
Re: ZoneMinder integration with Home Assistant
Is this a mobile app? (f so, then refer to the Mobile Apps forum section).
Sounds like an API issue. Look around for how to test if you've properly configured API use on ZM (web server is more so the issue).
No, it's not the mobile app. It's using my browser to access Home Assistant.
