Fail2Ban integration
gmar_87
Post by gmar_87 »
I've forked the latest version of Fail2Ban and added a filter and jail configuration for ZoneMinder failed web logins.
My changes can be viewed on Github and will hopefully be included in future versions of Fail2Ban.
https://github.com/fail2ban/fail2ban/co ... arz:master
Basically, add the following to /etc/fail2ban/jail.conf
[zoneminder]
# Zoneminder HTTP/HTTPS web interface auth
# Logs auth failures to apache2 error log
enabled = true
port    = http,https
filter  = zoneminder
logpath = /var/log/apache*/*error.log
maxretry = 3
And create the following file /etc/fail2ban/filter.d/zoneminder.conf
# Fail2Ban filter for Zoneminder login failures
[Definition]
# patern :      [client 10.1.1.1:38022] WAR [Login denied for user "test"], referer: https://zoneminderurl/
# Option:  failregex
# Notes.:  regex to match the password failure messages in the logfile. The
#          host must be matched by a group named "host". The tag "<HOST>" can
#          be used for standard IP/hostname matching and is only an alias for
#          (?:::f{4,6}:)?(?P<host>[\w\-.^_]+)
failregex = [[]client <HOST>:\d\d\d\d\d] WAR [[]Login denied for user
ignoreregex =
# Notes:
#	Tested on Zoneminder 1.29.0
# Author: John Marzella
PacoLM
Re: Fail2Ban integration
Post by PacoLM »
Nice job! I just added to my fail2ban configuration.
Thanks!
Miaou75
Post by Miaou75 »
Hi guys,
I got fail2ban working fine with sshd, but not with zoneminder.
I used your updated conf files on your github, enabled it, i can see the "login denied" on the apache2 error.log file but it does nothing.
When I try "fail2ban-client status zoneminder" I have 0 failed, why ?
What am I missing ?
Thanks for you help.
Miaou
gmar_87
Post by gmar_87 »
Miaou75 wrote:Hi guys,
What am I missing ?
Miaou
I've made some changes to the filter since posting this.
The old filter should work, but here is is the new regex that is less greedy.
failregex = ^\[\](?: \[:error\])?(?: \[pid \d+\])? \[client <HOST>:\d+\] WAR \[Login denied for user "[^"]*"\]
Also, if you copied directly from github, you may need to change the following line in jail.conf
logpath = %(apache_error_log)s
to
If the above doesn't fix your issue, post your config and fail2ban version here and will check.
Miaou75
Post by Miaou75 »
Hi guys,
I purged then installed fail2ban again and I managed to make it works perfectly fallowing your steps.
Thaks again
Drarox
Post by Drarox »
Hi Guys,
Thank you for your code gmar_87.
I just added it to my fail2ban configuration but I don't get the failed login errors in my apache log (/var/log/apache*/*error.log) so it's not working.
Can someone tell me how to have theses logs in my apache log please? Is there an option in the configuration of zm to do it or do I have to add a function manually to my zm?
Thank you :)
gmar_87
Post by gmar_87 »
Drarox wrote: Thu Feb 14, 2019 5:10 pm Hi Guys,
Thank you :)
You either need to:
1. Change the zoneminder log location in fail2ban's jail conf for zoneminder to your OS syslog
2. Enable web logging for warning level logs (Zoneminder web interface > Options > Logging > LOG_LEVEL_WEBLOG > Warning)
Drarox
Post by Drarox »
gmar_87 wrote: Fri Feb 15, 2019 10:23 am
You either need to:
Thank you for your answer gmar_87 :)
I used the second solution, I just had to change the [:error\] to [php7:notice\] in the regex of my zoneminder for my case and now It's perfectly working :D
noise
Post by noise »
Hi all
have anyone a working failregex with nginx ?
the only one log i found with nginx and zoneminder are:
/var/log/nginx/error.log
[error] 1619#1619: *3608 FastCGI sent in stderr: "PHP message: ERR [Could not retrieve user root details]" while reading response header from upstream, client: 192.118.199.165, server: 192.168.0.20, request: "POST /zm/index.php? HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.2-fpm.sock:", host: "192.168.0.20", referrer: "http://192.168.0.20/zm/index.php?"
sagitt
Post by sagitt »
works with zoneminder 1.34.9 and ubuntu 18.04.4
Fail2ban version: 0.10.2-2
I edited it for new version and added in case of wrong user. Now is "ERR" and not "WAR"
Of course need to enable WARNING as explained up.
/etc/filter.d/zoneminder.conf
[INCLUDES]
before = apache-common.conf
[Definition]
# pattern: [Wed Apr 27 23:12:07.736196 2016] [:error] [pid 2460] [client 10.1.1.1:47296] WAR [Login denied for user "test"], referer: https://zoneminderurl/index.php
# pattern: [Wed Apr 27 23:12:07.736196 2016] [php7:notice] [pid 2460] [client 10.1.1.1:47296] ERR [Login denied for user "test"], referer: https://zoneminderurl/index.php
# pattern: [Wed Apr 27 23:12:07.736196 2016] [php7:notice] [pid 2460] [client 10.1.1.1:47296] ERR [Could not retrieve user test details], referer: https://zoneminderurl/index.php
# Option:  failregex
#failregex =
failregex = ^%(_apache_error_client)s WAR \[Login denied for user "[^"]*"\]
            ^\[\](?: \[php7:notice\])?(?: \[pid \d+\])? \[client <HOST>:\d+\] ERR \[Login denied for user "[^"]*"\]
            ^\[\](?: \[php7:notice\])?(?: \[pid \d+\])? \[client <HOST>:\d+\] ERR \[Could not retrieve user [^"]*\]
ignoreregex =
# Notes:
#	Tested on Zoneminder 1.34.9
# Edited: Sagitt Cyber
/etc/fail2ban/jail.conf (make backup)
[zoneminder]
enabled  = true
#port    = http,https
port     = http,https
filter   = zoneminder
#logpath = %(apache_error_log)s
logpath  = /var/log/apache2/error.log
bantime  = 24h
findtime = 10m
maxretry = 3
noise
Post by noise »
thanks for the update... but i think changing the path to nginx are no working... have no one a zoneminder with nginx and fail2ban ?
