password reset
Pr0n
password reset
Post by Pr0n »
the idiot tech at my other store changed the password on my dvr and can't remember it, or made a typo (TWICE) I've still got root access to the machine of course, how do reset the zoneminder admin password?
kingofkya
Post by kingofkya »
fire up phpmyadmin
Go to ZM>USERS>IdiotsUserName>Password EDIT: remove hashed password making the password blank
snake
Re: password reset
Post by snake »
As a reference here's the entries for command line mysql/mariadb
mysql -u root -p
use zm;
show tables;
select * from Users\G
The idea is, blank the password out, then you can login with just username and no password.
vvchumanov
Re: password reset
Post by vvchumanov »
Why don't works whis>...??
i'm change in mysql password for admin, but in web /zm don't enter (write to wrong password!!) (in mariadb it's ok work) whats troubles zm this fall change password after update 1.32 > 1.34 :roll:
but in zmninja from api it's work great :/
