Hi!
Does ZMNinja support ZoneMinder 1.33.3? I updated everything and now I don't have videos. I checked the API and everything works there. Just wondering if something in 1.33.3 is incompatible with 1.3.050(ios)?
Thanks!
ZMNinja for 1.33.3?
Re: ZMNinja for 1.33.3?
The exact error in the logs is:
zms_m8 12885 ERR Unable to authenticate user zms.cpp 201
Which is odd because I can login through the browser and retrieve the info from the api that zmninja would request.
If this isn't supported yet, just let me know and I will downgrade to whatever version is...
Thanks!
Thanks!
I am pretty sure I posted this so that my computer would know that I was reaching out for assistance and it relayed to my server to stop acting up... I believe I may have disabled auth_relay at some point in the past when I was dealing with the zmeventserver setup because I am using ZoneMinder through a proxy. This is working properly once changing auth_relay to hashed.
All's well that ends well, I suppose.
Yes, AUTH_RELAY does need to be set to hashed.
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
