Storage Spread Over 5 Drives
srinivas
Re: Storage Spread Over 5 Drives
Post by srinivas »
knight-of-ni wrote: Fri Jul 22, 2016 7:09 pm See this guide:
https://pthree.org/2012/12/17/zfs-admin ... lesystems/
It is very helpful.
After you create the filesystem, change its mount point to point to /var/lib/zoneminder/events like I did
Hey there,
Very sorry to open an old thread.
Ive tried mounting the new ZFS filesystem in /var/cache/zoneminder/events but i get an error stating that Zone minder is unable to write to the location, therefore i dont see any videos in the folder.
Im very new to zoneminder and have been learnign about ZFS for the last week and am very excited about using it at home.
Any help would be greatly appretiated.
srinivas
Post by srinivas »
To offer a bit more clarity, i am running Zoneminder 1.32 on Ubuntu 16.04.
Followed all the steps as mentioned in the official documentation
You need to either change ownership or permissions on the destination directory. It's probably easier to create a directory in the mounted drive and chown www-data:www-data that dir.
Anyways
sudo chown www-data:www-data /var/lib/zoneminder/events
will likely fix your problem.
srinivas
Post by srinivas »
@iconnor Thank you very much. It did solve the problem.
